Nintendo DS Lite Console Logo
Posted on Aug 17, 2009
Mad OK when I turn on my ds it won't go to my action replay screen it just goes to my screen where it says please insert the game
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Aug 17, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
Helped
2741
Points
24
That is a very hard problem to fix.The action replay might be broken.Don't use them,because I used one and after using cheats the top screen to my ds stopped working.Action Replays can really screw you over.
Will not read game in action replay
well there could be 1 thing that is wrong. 1 ur ds might no be able read the action replay or that there is
3helpful
Action replay doesn't let me add codes in custom code list!!!!!
Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems:
* Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes.
* Code Manager PC software is reporting the console`s battery is low when it’s actually fully charged.
* Multicolored bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes.
* You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error.
If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased.
1. With your console powered off insert the Action Replay DS
2. Hold down buttons A+B
3. Turn your console on
4. With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down
5. Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen
6. If Action Replay DS doesn’t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again
I cant press next after i put in a code
Please make sure that you are entering the Game ID correctly. Follow these steps to find the Game ID before beginning the code entry process: •Turn on the Nintendo DS with the Action Replay inserted •At the Main Menu when you are instructed to “Insert Game Cart”, remove the Action Replay and insert the game. •On the top screen of the DS, the name of the game (or Unknown Game) will appear. •The number under the Game Name is the Game ID. Please be sure to include the dash when entering the Game ID into the Action Replay.
If this did not solve your problem, please leave a comment and I will get back to it as soon as I can.
When i turn my ds on with AR in it, the screen turns all white
may be your action replay is broken. try another action replay with another ds. also try your action replay with another DS.
9helpful
I wiped all my games! HELP ME!!!!!!!!!!!!!!
i had the same prob
* Multicoloured bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes. * You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error.
from codejunkies
1helpful
My ds wont accept the ards. My other ards wont put any new games in the bottom screen it goes blue and red?My computer (windows vista)doesnt accept my ards
Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems: * Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes. * Code Manager PC software is reporting the console`s battery is low when it?s actually fully charged. * Multicoloured bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes. * You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error. If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased. With your console powered off insert the Action Replay DS Hold down buttons A+B Turn your console on With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen If Action Replay DS doesn?t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again whats an ard? from code junkies
2helpful
2answers
Action Replay DS has deleted avery single cheat code it came with
source codejunkies
6helpful
My action replay code manager is empty and I want to add pokemon
You need to restart your action replay.
to do this follow these steps.
1. hold A and B while turning on your DS.
2. at the Nintendo screen hold start and select.(still holding A and B.)
3. Let go when the screen saying, nintendo dose not''blah blah'' this product.
4. Turn off when you see the action replay title screen.
Once restarted try and add a code.
I had the same problem, but i did the above.
6helpful
4answers
My ACTION REPLAY WON'T WORK!!!!!
Everybody has the same problem!! ITS UR ACTOIN REPLAY!!RETURN IT!!!!!!!!!!!!!!!!!!!!!!
you have the wrong answer action replay back to its factory settings ( the way you bought it )
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
