m
magic center Posted on Jul 02, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
OCE TDS 600 ERROR CODE 15502 - OCE Office Equipment & Supplies
Oce Guy
Level 2:
Wolfpack:
An expert that has 5 followers.
  • OCE Expert 309 Answers
  • Posted on Dec 03, 2019
Oce Guy
OCE Expert
Level 2:
Wolfpack:
Answers
309
Questions
0
Helped
186646
Points
457
Your paper switch may have failed. Look at the back of the machine. The thing under all those crescent shaped paper guides is called the Integrated Receiving Tray Paper Switch. If it is hanging off the system on one side ensure it is properly locked on the system by pushing it in. Under the paper switch on the left side (right side of printer) is a little box secured by a 7mm hexagonal head screw. Take the box off and see if the connector from the paper switch to the back of the machine is seated properly. If it is, it may be a failure in the paper switch itself. If so, please call an Authorized Oce Service Representative.
5 Related Answers
A
Anonymous
  • Posted on Aug 25, 2008
SOURCE: Oce TDS 400 Printer. Erore Prob.
erore
Nike Merritt
  • 149 Answers
  • Posted on Oct 05, 2010
SOURCE: OCE TDS 600 error code 22017. Do you Know what it
There is a problem in the power supply section. Call for service, this is not user fixable.
Anonymous
  • Posted on Sep 06, 2012
SOURCE: oce tds 600 Error code 15504 machine stopped in
There seems to be a feed problem. I googled the error 15504 for the Oce printer and got this page. We did this (see photo) and that seemed to sort the problem out for the meantime (until service guy gets here). I dare say it's a sensor somewhere. So jam a roll of cardboard from a used roll in behind the roller (as in the photo) and that does the trick. Hopefully this works for anyone else with the problem.
Anonymous
  • Posted on Apr 09, 2013
SOURCE: I have a OCE TDS 600 with an error code of 8519.
Replace the SSR Relay on the side close to the big sliver box.
roman_tolovi
Roman Tolovikov
  • 5 Answers
  • Posted on Oct 24, 2017
SOURCE: oce tds error code 12502
Upper paper roll drawer knife sensor failure and incomplete cut of the PRDU rolls.
Check the knife of the upper roll drawer.
May be the rubber tow, which make knife move, is broken. Or one of the sensors(left or right) is dirty. Or knofe motor is not working.
You can check motor movement by using service sds test 12-6-001.
Oce TDS 600 error code 15001 ?
More than likely the Paper Transport Suction Fan is the problem.
Oce tds 600 model no. the problem code is 05101
Severe developer pollution. When it gets to this error, there is no choice but to call an authorized Oce representative to troubleshoot and repair.
I have Oce TDS 600 and getting error code 08002. Please help me to fix this.
Problem with fuser unit. Please call an Authorized Oce Service Representative.
Oce tds 600 error code 08005
you can see you'r answer here:
http://www.copytechnet.com/forums/other-copier-brands/90112-oce-tds-600-08005-error-code.html
The Oce TDS 600 is a large format printer made by the company Oce. Error code 23501 on this printer typically indicates an issue with the printhead. The specific cause of the error and the solution will depend on the exact circumstances of the error. Some possible causes might include a clogged printhead, a malfunctioning printhead, or a problem with the printhead cable. It is recommended to check the user manual or contact Oce technical support for more specific troubleshooting steps.
Oce tds 600 error 04501
It's either the printhead or the printhead NTC.
Oce TDS 600 Error Code 10501 and 22019
Protocol versions conflict. Call an authorized Canon/Oce technician for service. The scanner will have to be reflashed with new firmware. This can't be done by anybody other than a technician with proprietary software.
Oce TDS 600 scanner error code 10501
Clean mirror and scanner glass. Be extremely careful cleaning the mirror. Its a First Surface Mirror and extremely expensive.
OCE TDS 600 error code 22017. Do you Know what it is >?
Error code 08519 on Oce TDS 600 - looking for service code list
Sounds like an NTC in the heater is gone. The NTCs are ceramic and are extremely easy to break. I would suggest you get an authorized service technician to replace it. This might also be the entire fuser assembly.
Top OCE Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Ngoro
Are you an OCE Office Equipment and Supply Expert? Answer questions, earn points and help others
