There is a
possibility that there is an
object in between, creating pressure from inside so the latch is stuck engaging the
striker. (these objects may be the carpet, wires, the body seal, etc)
First: Push down the trunk while you unlock it.(while you doing this you may listen a mechanical click that means that latch release the
striker.)
Second: At the same moment you listen the opening noise, release the push down pressure and pull up the trunk open.( perform this until you achieve the right timing the latch job is to comeback and
engage the
striker so do it several times).
Another scenario if you have an electronic actuator.
First make sure you that when you press the remote or switch for the trunk there is a little click, if there is a click use the technique above push trunk lid and at the same moment that clicks pull up the lid releasing the pressure down.
And the last option almost all the vehicles had the option to
access the trunk from the back seat, and almost all vehicles have a release handle to bypass
mechanical latch or electronic actuator.
If you need further help, I’m available over the phone at
https://www.6ya.com/expert/flavio_517b938f50183b92
I don't think it has to with that but more with the actual latching mechanism, it is noisy when I press the release button, I think it may be sticking.
Has anyone had some simmillar problem?
TIA
