When you turn player on: Screen said "Hello" , then "Protection"
Sounds simple... usually "protection" means that a speaker or a speaker wire is shorted out. Or that the volume is just too damned high... how loud is the receiver's volume setting? If the bass tone control is jacked and the loudness button is on, even with no shorted wires, the amp can go into protection from an internal overdrive. Might be that you just need to do like your mom says and turn it down!
If you have an ohmmeter, speaker or wiring problems are easy to test, if you don't, you can still do it all mechanically... here's how
Turn off the receiver and start by disconnecting your speaker wires at the back of the receiver. With all of the speaker wires removed, does the thing still go into protection when you turn it back on?
If not, good. If it does, find a service center.
Re-connect the speakers to the appropriate terminals one speaker at a time, turning off the receiver each time you make a connection. After connecting one speaker, turn the receiver on and see if it shuts down. If not, then turn it off and add one more speaker.
Do this until you find the culprit. Leave that suspected bad speaker's wires disconnected from the receiver and test all the rest, connecting all but the bad wires.
Now, disconnect the speaker from the other end of the bad wires and spread the bare wires apart so they don't short out. Connect the wires ONLY at the amplifier end and turn the amp back on. Protection?
If yes, the wire is shorted out somewhere. got cats?? If everything is OK, turn off the receiver and reconnect the speaker and test again. Make sure the wires aren't shorted at the back of the speaker. You really need to check all the speakers to make sure their connections are "clean" and make sure that there are no stray wire strands anywhere or that the wires aren't stripped too much so they might be able to short out. After the wires are connected to either a speaker or an amplifier, you shouldn't be able top see much of any bare wire, but you already know that, right?
Some folks strip way too much off the wire and the wires simply touch the wrong things and ... badness happens.
If all the connections are clean and the receiver still shuts down when this speaker is connected and the receiver is turned on, swap a working speaker onto these wires, leaving the suspect speaker disconnected and making sure the other bare wires won't touch anything or each other.
Back on with the working speaker... good? If so, then we're determining that the problem is probably in that one speaker. If not, then we have a deeper problem.
Reconnect the suspect speaker to the other wires and try again. Good? Then you have "fixed" the problem by cleaning up the wiring connections. If it shuts down again, then you need to fix or replace the bad speaker.
If everything works now with the volume down and such, then just use a little self control. If it's still messed up, you may need a trip to the service shop
Good Luck
