Apple 13 MacBook Notebook Computer  Z0H1-0002 Mac Notebook Logo
Posted on Aug 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Installed Parallels on mac but cannot connect to the internet.
I installed parallels on my macbook. i know for a fact that macbooks are wi-fi ready and i can attest to that. now i tried using the windows on my mac but i can't seem to find an internet connection. what's wrong???
Anonymous
Level 3:
  • Master 1,305 Answers
  • Posted on Aug 13, 2009
Anonymous
Master
Level 3:
Answers
1305
Questions
0
Helped
596447
Points
4327
When running your mac in the windows mode, insert your mac os dvd into the drive. It will launch the program to install all the software and settings to make your windows os very "mac-like".
I had the same problem. Mac has thought of that for us! Insert the Mac disc, let it fully run it's installation WHILE YOU"RE IN Windows os. It'll set up all the settings for wifi and everythng that one would normally have to set up in windows.
If you have a printer that you want to use on the windows os that is already working in the mac os, you can download a copy of bonjour from apple. This program will get your printers up and running as well in os.
Copy windows 7 and apps to Parallels desktop
First you create bootable windows disk, and then you try it. Bootable Disk insert to DVD rom drive and follow instruction on setup.
More info please visit this link.
http://www.lgsolutions.com/ftgsoftware/downloads/Windows_XP_Installation_Guide.pdf
Thanks,
Apple Support
I ve a mac, how can I use Bernina software
Select and install virtualization software for your MacBook Pro. You can choose from several popular virtualization packages for the Mac, including Parallels Desktop for Mac, VirtualBox and VMware Fusion. VirtualBox is a free, open source software package, while Parallels Desktop and VMware Fusion are commercial software products
Install Windows within your virtualization software. You much purchase a copy of the Windows operating system if you do not already own it; it does not come with the virtualization software. Most virtualization software includes a wizard, or assistant, to guide you through the Windows installation. Windows will now run in a "virtual machine" on your MacBook Pro.
Install your Bernina Artista Embroidery Software on your virtual Windows system. You install software into the Windows virtual machine the same way you do on a physical PC.
Plug the Bernina security dongle into a USB port on your MacBook Pro. The Windows virtual machine acknowledges the dongle, and may ask you if the USB dongle is to be used with the Mac or Windows system. The dongle is a hardware device that provides copy protection for the Bernina embroidery software.
Run the Bernina Artista Embroidery Software by choosing it from the Windows Start menu
4helpful
Iam ahmed morad Want Driver For apple macbook A1181 For Win7
You can install Windows 7 on a MacBook using either Apple's Boot Camp, VMWare Fusion, Parallels, or a combination of these.
Once you have finished installing Windows 7, you should shut it down, insert the gray disc #1 that came with your Macintosh, then start up Windows and let the disc contents autorun. This will install Windows drivers for the Apple hardware. If the disc does not autorun, just run it manually from My Computer.
I need to know how to install Windows XP on Mac. Thank you!
The easiest, and my personal favorite, is to use Parallels Desktop for Mac:
http://www.parallels.com/products/desktop/
If you're not into desktop virtualization (running an OS inside of another OS at the same time), you can do something called dual boot, in which you'll have the option after you turn the computer on to use either Windows XP or Mac. You'll have to reboot everytime you want to switch, though.
http://nirlog.com/2006/03/18/winxp-and-osx-dual-boot-in-macbook-pro/
Remember to keep a current backup of your data before attempting a Windows XP installation.
Boot macbook problem
Parallels won't have caused this, Bootxchanger might have but it's not likely. More likely is that you HD is faulty.
A largish number of white Macbooks shipped with faulty Seagate HD which, although fine to start with, started failing after about 1 year of use.
I've seen 3 in the last six months.
Thankfully the HDs in these MacBooks can be changed in just a couple of minutes, the bad news is that the data on the drive is generallycompletely destroyed.
Try starting up from your install DVD, but not do the install. After you get asked about language, at the next screen, go up to the menu bar and locate disk first aid. Run that - you may be lucky and it fixes it or you may not.
3answers
Parallel Desktop on Mac OS X
Ahh - Parallels is working but can't locate the disk image for XP (assuming) that was created by Apple's BootCamp.
Locate the image "disk0.hdd". Once found, copy it to your "Documents/Parallels/My Boot Camp/ " folder (you're logged in on the Mac as jeremybrunelle right ?)
Parallels
Install bootcamp. It is the certified parallel for the dual core. If you already have it installed, try installing XP again, or Vista.
MacBook
If you purchase a program called Boot Camp, VMWare Fusion, or Parallels you can load both XP and OSX to run dually or separate.
3answers
Parallels Desktop
Hi toy4runner,
Did you check the permissions of the folders that need to be openend by parallels to get to the file? (just select the folders one by one and for ech of them press apple - I and check the permissions section of the information pane. Chnaces are Parallels is trying to access a folder but doesn't have the right permission.
If all seems okay, check this:
http://kb.parallels.com/en/4680
Hope it helps
3answers
Parrallels
I would suggest you look in to Apple's Bootcamp. Although you do not want to run in a dual-boot configuration, Bootcamp allows you to create a CD with all of the Mac's windows drivers.
I appologize but I am not totally sure if 1) the Bootcamp drivers contain a camera driver and 2) if the camera works at all within Parallels.
Worth a shot though.
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
