Hello Jake. It depends on whether or not you have a 3 prong cord (3 wires), or a 4 prong cord (4 wires). So I'll just tell you both.
For Three Prong Cords
the Center cord wire goes on the center
terminal,
the left on the left ,
and the right on the right.
Note:
There should be a ground strap or wire that runs from the center terminal to the
dryer case
Here is an example of a 3 prong cord for a whirlpool dryer. If your terminal block has 5 screws, you still do it the same way as stated above. these wires are not colored. You should have a strap in the middle that is connected with the middle wire. Sometimes there is a wire attached there instead of a strap.
For Four Prong Cords
the White cord wire goes in the center,
the
Red on the Right,
the Black on the Left.
The green cord wire goes to the
case or the external ground screw.
Here's an picture to use as an example;
Just be sure to use the strain relief at the opening where the power cord first enters the dryer. It will help secure these connections against being pulled loose or cut on the cabinet, and that could pose a risk of you coming close friends with 240 volts. Not a friend I want to have.
I hope this is helpful,
If you have any questions, feel free to ask.
thanks for using fixya
Mike W.
