Casio FX-115ES Scientific Calculator
Problem for Casio FX-115ES Scientific Calculator
How do i display decimals on casio fx 115es
By josh_nether on Aug 12, 2009
how do i display decimals on casio fx 115es
Best Solution
posted on Aug 17, 2009
Helpful)
k24674
Rank: Guru  Casio Office Equipment  Expert
Rating: 87%, 672 votes
The instructions are below the screen. It says Mode arrow and a table of numbers.
If you want to set (use) degrees, you press the MODE key followed by the 4 key. On the top of the screen deg will be displayed.
If you want to set RAD or GRAD, similarily, you press MODE followed by 5, or MODE then 6.
However if you want to convert a result displayed in a particular unit into other angle units, you press SHIFT MODE then 4 or 5 or 6, whichever is the case for you.
Hope it helps.
Comments:
Sep 24, 2009
- The answer does not applies to the FX-115ES, but to another calculator FX260 Solar.
For the FX115ES fractions anre converted to decimals by making use of the [S to D] key. If you want all results to display with decimals use [SHIFT] [MODE/SETUP] to select
[6:FIX] n where n is a number between 0 to 9 decimal digits; exemple 4 xxx xxx. dddd
[7:Sci] n where n is a number between 0 to 9 decimal digits ; exemple 4 x.dddd * 10^( ±dd)
[8:NORM] 1 or NORM 2 .
Oct 31, 2009
- If you do not need fractions and radicals, you can set calculator Input/Output to LineIO, To do so press [SHIFT][MODE][2:LineIO], and all results will be in decimal format.
If you need to reset the default MathIO (with fractions and radicals), just press [SHIFT][MODE][1:MathIO].
When in MathIO, a result in fractions or radicals can be converted into decimal format by pressing the [S<->D] key.
Also when in MathIO, and you want a result to be displayed decimal format, instead of pressing =, press [SHIFT][=].
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Casio FX-115ES Scientific
Questions and Unsolved Problems for Casio FX-115ES Scientific
Do you recommend Casio FX-115ES Scientific Calculator?
Answer
Answer
casio 991ms model calci display is very dull some times not visible at all
Answer
A telemarketer with B2B Communications has a 20 percent historical probability of making a sale... (More)
Answer
1 7 a -5 -7a -25 a 35 25 what are the two ranks and two values of a for this matrix?
Answer
x-12 ---- x-1 ... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Casio FX-115ES Scientific...:
Top Calculator Experts
Rank: Guru Guru
Solutions: 756
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Calculator Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
