Microsoft Xbox 360 Console Logo
Posted on Aug 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screen reads "open tray" and will not play a game
When trying to play a game, the screen reads "open tray" and will not play the game.
Anonymous
Level 2:
  • Expert 53 Answers
  • Posted on Aug 12, 2009
Anonymous
Expert
Level 2:
Answers
53
Questions
Helped
16111
Points
136
U should send xbox back to micro center
I went to put a game in the xbox to play,I waited for it to load & nothing happened.The screen said open tray.I waited & waited but nothing.I pressed the green button on the controller but the tray...
Well you may be having disk tray issues, sure hope so as compared to a burnt out lens module,try ejecting the tray fully and wiping all dust off around the grooves under the tray,one more tip is to keep a disk in the drive at all times, even when you aint playing it, you can also try giving it a gentle tap on the front pat where the disk tray is located any time you eject it or push the tray back in, come to think about it if you are fond of pushing the tray in after inserting a disc, stop cos it weakens the motor that drives the ejecting process, hope this helps...
The xbox 360 elites keeps on saying open tray when trying to play
1, the disc may be dirty
2. the mian reason for this your xbox drive cannot read the disc , because the power of the lens is gone(not completely) ,
solution:
1. keep your disc inside the drive and switch off the console, again swith on try this 2 to 3 time
2. keep the console in vertical position or little slanding position(180 dg) make sure it does not fall
3. its better to buy hatddisc and load the game inside it , so that u lens life increased
4. change the entire drive
Open/Close tray message
This means that you need your DVD drive replaced. If you are under your 1 year warranty from MS go to www.xbox.com/support and fill out a repair request. If you are out of warranty make sure that you only let an experienced professional perform this repair. If you do the repair on your own, or have someone that doesn't know what they are doing do it then it's very likely your Xbox will never play games again. There is vital information on the old DVD drive that must be extracted and put into the replacement in order for your 360 to allow it to play games. I can do this repair for you if you'd like. Email me at [email protected] for more info.
1helpful
Xbox 360 open tray message; not reading discs
If it won't play any games it might be the laser that reads the disk. I would suggest getting it checked out somewhere.
Open Tray
it might be because game eye need to be clean
2answers
THE SCREEN SAYS TRAY OPEN AND ITS CLOSED AND WILL NOT RESPOND
This happdends when the arm that the eye of the drive sits on doesn't go up. So it thinks the drive is open. You could try to open it up to see if you know about these things and try to fix it. Or just buy a new drive they run about $50
It only plays Normal Xbox games
The open tray and unplayable disc is because the lens isn't strong on the drive and needs to have a Pot calibration done to it to make the lens signal stronger. That should fix the open tray/unplayable disc issue. I have done this to quite a few drives and all have been working fine since.
My xbox 360 doesn't play my games
it could be that u got **** like food in your x box360 open it up and clean it out put it back to gether and try it if this dose not work tell me at [email protected] ty
the lens of the disc drive needs a check up...
HAWX open tray
If it says "reading" you just have to wait. H.A.W.X. is a big game.
If it says "open tray" you have to close the tray :)
Unless, Check the CD for scratches and marks, or else try the CD on another Xbox 360 console.
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
