Computers & Internet Logo
Anonymous Posted on Aug 10, 2009
My computer reboots without warning at different intervals
I will be on my computer sometimes just an hour .. other times 24 hrs or 36 hrs .. and then without warning the computer will just reboot. Sometimes my UPS (Power bar thiny) will beep but other times nothing. The computer gives me no clue that it will reboot. Next thing I know my monitor shuts off and then my computer is rebooting. Computer doesn't beep itself when this happens so nothing to go by. No errors neither. It is simply like loss of power.
Anonymous
Level 2:
  • Expert 93 Answers
  • Posted on Aug 10, 2009
Anonymous
Expert
Level 2:
Answers
93
Questions
0
Helped
22575
Points
288
This problem occurs if your computers cooling is not as its necessary to be.try useing it with an open cabinet and see if the problem persists. if the problem still persists remve ur CPU fan and place some heat sink fluid and place it back on the cpu. then all your problems should be gone.
use a good antivirus to check for any viruses before this(just in case)
I just changed the oil and filter on my LX420 twin cam how do I get the blinking light to go out. Its a 2006
  • The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display.
  • The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time.
  • CHG"/"OIL"/TIME will alternate on the display for five (5) minutes after the meter reaches 50 hours.
  • While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five (5) minutes.
The display will also flash as described above for five (5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two (2) hours.( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...)
THE METER DISPLAY WILL RESET TO NORMAL AUTOMATICALLY, after the reminder maintenance time interval of two (2) hours. There is no method of manually re-setting this Service Monitor gauge.
How do I set the time?
S E T U P
SET UP is performed once during
installation to set the internal CLOCK, ASTRO (sunrise/sunset)
times and HOLIDAY references. After entering and okaying the
ASTRO Zone, the timer will display calculated "center of time
zone" times when prompting for sunrise and sunset entries. You
may OK these, enter actual sunrise/sunset times or enter offset
times for early or late ASTRO operation. Sunrise time must be
before noon; sunset time must be after noon. Sunset must not be
within 5 hours of sunrise. Both sunrise and sunset must be
entered, even if only one is used for switching. If neither is
required, you may skip ahead by pressing HLDY or PROG keys.
(See map pp. 24-25 for details.) Holidays are entered with 2-digit
reference numbers; a chart for recording the date(s) is located on
page 22. Leap years are preset through the year 2094
PROGRAM is used for entering or
changing the switching schedule for loads wired into the time
switch. You can program circuits separately or concurrently. Each
entry affects loads whose Enable switches are in the enable
position at the time of data entry (2 circuit models only). The
time switch is shipped in a 12-hr. AM/PM mode; you can change
to 24-hr. by removing a jumper on the circuit board (see Special
Instructions). It can store a minimum of 400 events, depending
on the data type entered.
The time switch prompts you through SET UP and PROGRAM
with LEDs that advance after each entry. There are five important
points to remember:
1) The RUN/SET switch must be in the SET position to enter,
review or change data.
2) You must press "OK" after each entry, before starting the next.
3) You must press AM or PM after entering time (unless
programming Sunrise and Sunset or in 24-hour mode).
4) When in PROGRAM you must select the loads you want to
control with the Enable switches (2 circuit models only).
5) RUN/SET switch must be returned to RUN position to enable
automatic control and to save changes to data.
KEYPAD
SUN
MON
TUE
WED
FRI
SAT
DY
ND
WK
WK
6
7
8
9
These keys are used for most data entry. Note dual functions,
numeric or day specific. Using the day group keys WKDY,
WKND and ALL (for all 7 days) greatly speeds the process.
The keypad keys are only functional when the RUN/SET switch is
in the SET position. Pressing keys when in the RUN position will
cause a message to scroll, explaining the function of that key. Press
any key once to stop any of the scrolling error or help messages
You must press AM or PM after entering time data (except Sunrise
or Sunset) unless in 24-hr. mode. Programming fixed times for
ON and OFF events does not require PULSE, INTVL or ASTRO
keys. Multiple ONs or OFFs can be entered by pressing OK
without programming the alternate OFF or ON. Multiple OFF
times are frequently used to "sweep" off loads which have been
manually switched on after normal occupancy hours.
PULSE and INTVL (Interval) are length-of-time based options.
Maximum Pulse is 127 sec.; minimum is 1 sec. Maximum Interval
is 6 days, 23 hrs., 59 min.; minimum is 1 min. To program Pulses
or Intervals, press the PULSE or INTVL key after entering a Switch
On or Switch Off time; then enter the required duration and press
OK. Note after ON Pulses or Intervals have timed out the load
will be OFF, and after OFF Pulses or Intervals have timed out the
load will be ON, regardless of the load state prior to the start of
the Pulse or Interval. The INTVL and PULSE keys include a
temporary override function with a maximum length of 6 days, 23
hrs. and 59 min. for the interval or 127 seconds for the pulse. To
program an interval or pulse for override, select SET, enable the
circuit, press PROG, press INTVL
or PULSE (without selecting a
day), key in the interval or pulse
Intermatic ET70115C User Manual Page 4
My zeepad not coming on charge it for a couple hours still coming on.
First Battery charge often takes from 24 to 36 hrs.to fully charge.
How do i know who much time it takes to defrost a whole chicken?
Defrosting times for the Refrigerator Method 5 lbs -
7 lbs -
10 lbs -
12 lbs -
15 lbs -
24 hours (1 day)
34 hours (1 day 10 hrs)
48 hours (2 days)
58 hours (2 days 10 hrs)
72 hours (3 days)
43helpful
How do i reset the change oil light on a 1040 cub cadet 1000 series
The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display. The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time. "CHG"/"OIL"/TIME will alternate on the display for five(5) minutes after the meter reaches 50 hours. The display will also flash as described above for five(5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two(2) hours ( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...). While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five(5) minutes. The meter display will return to normal function automatically after the reminder maintenance time interval of two(2) hours.There is no method of manually re-setting this Service Monitor gauge.
1helpful
I have a White ride on lawn mower model 606....Just turned over 50 hrs. Pretty well at about that time the oil light and charge light came up and are alternately blinking and wont go off when the motor is...
I dont know about your White ... I have a mower at the job that has an hour meter and that hour meter flashes that the engine needs service at certain intervals. It doesn't know if service has been provided or not ... it just measures time and flashes this message at certain intervals. It flashes the message for about 30 minutes <> then goes off.
That is not to say yours is the same technology.
I would be willing to say the place you bought your machine knows the answer to this question without equivacation.
Thanks for your interest in FixYa.com
Jun 07, 2010 • Garden
8helpful
I purchased a lampmaster #38439 timer and I need to know how to set it, to turn on and off the lamp.
it shoudl have had instructions with it in the box
Find the arrow on the face and rotate the dial to the arrow to set the correct time. Then with a suitable instrument or long finger nails raise the divisions on the rotating wheell to the TURN OFF TIMES the ones left are thye intervals of actual live time. Each segment is 15 minutes so one down 1 up is 15 minutes of ;lighted time and so on for 24 hrs the wheel is divided into day and night time by color 12 hrs of darkness and 12 hours of daylight time
Please rate my help++++Thanks for using FIXYA
1helpful
I lost my setup CD-ROM. I cannot setup my computer without my CD-ROM
GO TO THE WEBSITE OF THE BRAND OF YOUR COMPUTER AND MOST TIME YOU SHOULD BE ABLE TO DOWNLOAD A SETUP DISC OR ORDER ONE AT LEAST. AT THE WORST YOU COULD GET AN OVERNIGHT DELIVERY ON A DISC AND BE BACK IN BUSINESS IN 24-36 HRS. THEN, MAKE COPIES OF THE DISC! BUT, MOST BRANDS WILL HAVE SETUP DISCS AVAILABLE. TRY THEIR WEBSITES. GOOD LUCK.
Grand Canyon Tech
Grand Canyon Tech
