Ignore the disc that comes with the player.
If using windows media player I simply ripped the tracks off the cd into mp3 to get them into the windows media library then synched the tracks to the player.
When you connect the USB cord between the computer and the player, windows media player will recognise it and show it in the left side bar.
Click on the mp3 player icon and then synch the tracks into the plyer list to import to the player (right side bar) I simply synch them all then remove the ones I dont want or drag and drop the mp3s from my media library into the player list to be synched.
Ignore totally the disc that comes with the player it is not required I think its only for 98 users to make it work it is not required with XP or Vista simply upload tracks to the player using a media player such as windows or real player.
So rip mp3s from the cd you want ....
When in mp3 mode (ignore if already mp3 on your pc) click the player icon when connected to the pc with the USB cable then select synch.
There are two ways to format an Mp3 player - one on the computer
itself, and one in Windows Media Player. Both methods will end up
erasing all the songs on the player, but the player will be "good as
new" after that. Sometimes reformatting in this manner will override
the player's native formatting and cause problems - this can be
reversed in most cases by updating the player's firmware. Firmware
upgrades are available from most manufacturers' websites. WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or
FAT32. - Connect player to computer, double-click my computer, right
click on icon of mp3 player and select format. This only applies to
Windows-based computers. You can also format the player in Windows Media Player itself: Connect your Mp3 player to the computer and open Windows Media
Player. Click on the Sync tab. Pull down the drop down menu underneath
the Sync tab by moving your cursor over the Sync tab and left clicking
on the little black arrow underneath the Sync tab. Highlight "name of
Mp3 player here 1GB" (wording may vary slightly), and then select
"Format." - this should erase everything. -Tha Mp3 Doctor
Most likely a issue in the FAT or similar table. The tables used on the internal memory is allocated only for short files names since most media managers change the file names to fit 8.3 dos. They do this since mp3 and mwa audio files use id tagging. So try renaming your mp3's that its eight letters or numbers then the three letter extension .mp3 = rap0001.mp3
whichever it is your problem maybe because of the fact that some players have only a certain limt of space alloted for recording.for example:in a normal 1 gb player with voice recording function only about 28 hrs(approx. 128 MB ) of voice can be recorded....even if there is plenty of space left in the player the player will not record voice once the full 28 hrs has been used................This recording facility can be reused by deleting the old recorded files.....
Well it's not really a solution, just a work around. I don't know why it does this but if you add a new folder you can load more stuff it that. At least that worked for me. I don't know why you just can't put it all directly on. Pretty stupid.
I would suggest formatting the unit and trying again, but this time do not sync it with media player.
Plug it into your USB and got "My Computer", the player will show up as a removable disc usually drive f:, right click on the drive and hit format, quick format shoudl work. Once formated double click the removable disc drive, and then click and drag or copy and paste your music into this drive and see what happens.
That player should support WMA files, but just to let you know, if you convert those files to MP3 it will take about half the space and therefot you can store more music at once.
L8R
Hope this helps and good luck
