Televison & Video Logo
Yong Lo Posted on May 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Westinghouse TV mod DW50F1Y1 could be turn on and back light turn on and show logo W and channel 64.2, after 10-20 sec it turned off by itself.
It has no sound, channel do not change with remote control. Try to reset a few times but no avail. Is it power supply board defect?
Franco Dosil
Level 3:
Top Expert:
  • Westinghouse Master 10,542 Answers
  • Posted on Jun 19, 2019
Franco Dosil
Westinghouse Master
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
379334
Points
178965
Hello Yong, for what you say, your Westinghouse DW50F1Y1, would need a firmware update, look at www.westinghouse.com for the updates available for your model and the downloads in an empty USB memory, without any file and then place it in the TV and update the Firmware
Hola Yong, por lo que cuentas, tu Westinghouse DW50F1Y1 , estaria necesitando una actualizacion del Firmware, busca en www.westinghouse.com las actualizaciones disponibles para tu modelo y la descargas en una memoria USB vacia, sin ningun archivo y luego la colocas en el TV y actualizas el Firmware
https://www.techwalla.com/articles/how-to-update-a-westinghouse-lcd-tv
http://westinghouseelectronics.com/support/downloads
5 Related Answers
Anonymous
  • 116 Answers
  • Posted on Mar 05, 2008
SOURCE: Mitsubishi WS-65313 - Will not turn on
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Anonymous
  • Posted on Feb 02, 2009
SOURCE: Magnavox 50" plasma Won't Power on/Shut's off/Blinking red LED
The above fix, listed by Tom saved us!! We did as instructed and took off the back of our 50 inch Magnavox plasma tv. We were not sure what we were looking for so we googled capacitator (image) & there was a photo of a fried capacitator! Sure enough we noticed ours were "fried", we took out the board and went to an electronic supply store, bought the 2 capacitators ($2.00 each!!) and then found someone who did tv repair to sauter the new capacitators onto the board. (It is important someone who know how to sauter and recognizes polarity do do this for you) All in all we fixed this following the above instructions for $34.00 and our time. For a month we were told to spend hundreds getting a new power board!
Kudos to you Tom & thanks so much!!
Anonymous
  • 4 Answers
  • Posted on Apr 03, 2009
SOURCE: Westinghouse tv ltv46w1hd sound no picture
www.cfusion.com has the spare parts for that tv. it sounds like it is the mainboard. shouldn't be more than 150-200 to replace.
Anonymous
  • 523 Answers
  • Posted on Jun 05, 2010
SOURCE: Vizio P42HD turns on with sound, although no picture
panel
Anonymous
  • 3 Answers
  • Posted on Jun 12, 2010
SOURCE: Westinghouse SK 32H540S when i Turn on TV, get
The problem is cause by the transformer on LIPS inverter (Power supply + Inverter board). You could see an obvious burn on the 1 of these transformers ( There are total 3 black transformer on this board). The part number is 4302H. It is available online at http://www.lcdparts.net/TransformerDetail3D.aspx?ProductID=2775
Westinghouse ew32s5kw tv red light shows power is going to unit pressing power turns indicator light from red to blue for a brief moment then back to red.
I had the same problem on my Westinghouse 32 inch TV. The internal main power supply went bad and had to be replaced. I had a TV repair shop do it. It was about 8 years ago. Haven't had a problem since. I think it cost about $70 for parts and labor. Nowadays TVs are pretty much a throw away item if they go bad. TV repair shops are getting hard to find plus the cost of TVs has come down so much sometimes you can get a new set for what the repair would cost!
I have a Westinghouse LCD TV, model #CW40T6DW. The TV turns on shows the Westinghouse symbol, channel number and then turns off.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
2helpful
I have a Westinghouse W3223 TV which has decided not to turn on any more. It powers up just fine as always. But instead of showing the video input source before showing the picture, now it shows nothing...
This going to be tough one to figure out, but at least the back light inverter board and power supply are working, unhook it at least 1/2 hour?
You may have bad main logic board problem. Try reading my guide here and see how much the main baord may cost you.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
5helpful
2answers
Westinghouse SK 32H540S when i Turn on TV, get Westinghouse logo, picuture turn on for 2 sec then black screen.
2helpful
Westinghouse SK 32H540S Turn on TV, get Westinghouse logo, picuture turn on for 10 sec then black screen.
Hello, it sounds like you need to replace the inverter board, I believe this model has LIPS board which is the power board and the inverter board put in to one single board. You can find price and availability for parts by emailing [email protected].
No picture just audio
if you have cable tv its probly just the cable is loose try tighting it. if that doesnt help try changing the settings. if that doesnt work then theres a slight chance you might have a bad cable
1helpful
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
