An oil can light is showing on the display screen and now the motor is making a very loud consistent noise
Hi, If the oil light is on and the motor is making noise, stop using it until you can fill it with oil. It should have an excess plug of some type showing you where to add the oil. Look around for it. If you find it and it is low fill it up. If it is full, the motor is going out on this unit. Good Luck,
Shastalaker7
Check Your Oil Level. If level is good, you may have bad pump or broken slinger
