Flash Board part number is as follows.. 147667311... FLASH UNIT, available in Part Store. If you are not comfortable with replacing above flash board in DSC-S85, take camera to qualified camera tech because camera will be apart in detail to replace flash board. Thanks.
Hi! Try initializing the camera. Error 91 is a flash error in Sony cameras. It is probably a dead flash fuse on the motherboard (most common problem) or a faulty flash board. If you have a multimeter, I can help you locate and test the fuse and if you have a soldering iron - even fix it. My e-mail is [email protected]. Otherwise, you should contact your local Sony service center or other local camera service center.
Hi, Its an error of flash unit(E:91:01 denots flash unit problem) which get started malfunctioning. Therefore you have to replace the FLASH UNIT ASSY. For changing of flash unit assy. You can contact any sony service centre nearby to you. For your convenience please visit: www.sony.net or www.sonyworld.com Here you can find contact info of nearest service centres. Thanks for using FIXYA.
Hi there, If you have tried all the flash settings and still no flash: this unit has a fuse on the flash board that may be open or the capacitor that holds the charge for the flash also may be shorted. A service shop could give you an accurate estimate.
mr cicmo.
