Http://nds1.nokia.com/phones/files/guides/Nokia_6070_UG_en.pdf
hope this link helps u better
All the best
Prince
SOURCE: sim card rejected / insert sim card
Unfortunately, they usually fault after getting wet. You might want to take it to a local repair facility and have them check the internal circuitry. Best of Luck.
SOURCE: problem no sim card inserted
try to clean the contacts of your sim-card and also on your phone
if not see if your sim-card bends a little try to flatten it. ok...
peace!
SOURCE: Insert SIM Card message in nokia 6080 though SIM is inserted
May be its detecting your sim card properly. Check your sim card in another handset. Verify if its the propbelm with sim card not your handset.
SOURCE: Nokia N70 Insert sim card problem.......
i can solve this
if you want to format your memory follow this:
menu>tools>memory>then press options>from the list select format mem.card.
SOURCE: instructions on how to insert sim card
hello. there is often a diagram which shows u how to insert the sim card. it will be a little diagram of a box shape with a **** on one side, as ur sim has a **** on one side too. try looking for it. the sim insertion can be under the battery, or more rrarely- thru the side of the phone. dont get confused with where the memory card fits, it is much smaller in size.
