Nokia 3110 Cellular Phone Logo
Posted on Aug 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The LCD of my n3110c suddenly flickered and turned black.
It still turns on. I think it still functions normally except for the LCD. It still lights up but it flickers and turns dark.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 270 Answers
  • Posted on Aug 06, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
270
Questions
0
Helped
101637
Points
719
Have ur handset fallen off . try to reaasmble the display connector assembly with help of a technician
Balaji
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 02, 2014
Balaji
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
96
Points
Just wash the display connector with ipa
1helpful
How do I fix my LCD TV's ability to display picture?
it may be from inventor board that make light for screen.
1helpful
My TV turns on with only half the screen working, the other half is pitch black. It remains this way for about an hour and then works normally, except for a little flickering towards the edges. What is...
Hi Igor,
This is happening due to the lose or bad contacts in the LCD panel. Fixing this kind of troubles is a highly risky and delicate job. If you are not a practising technician, please let some good Technician do it.
Good luck.
Vaio LCD problem
Periods.......Nice little items because they denote the End of a sentence.
See how this works?
"I have a vgn cs36gj, I was working with it, suddenly the LCD became pale black, I connected it to external monitor and it has a picture, sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
Now you try it.........
"I have a vgn cs36gj. I was working with it, suddenly the LCD became pale black.
I connected it to external monitor and it has a picture."
Okay, I got that part.........
"sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
WHICH LCD?
Laptop LCD?
External monitor LCD?
Man on the moon LCD?
1) If the external monitor LCD goes 'pale black', the problem is the graphics chipset.
This I do not believe
2) If the laptop LCD goes pale black, this I believe.
Post back in a Comment.
Regards,
joecoolvette
3answers
My Acer AL2216W Black LCD Monitor all of a sudden is wavy & flickering!?!?!? Is there anything I can do about it?
Hello,i think your LCD monitor is faulty and you should consider replacement.but first take to a qualified service personnel.
Screen flickering when turning on laptop and sometimes the laptop turns on after flickering and sometimes doesn't turn on at all after flickering. Just stays black.
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Black screen
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
1helpful
HP pavilion notebook screen turns black after flickering
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
HELP ME FIX MY MONITOR PLEASE
same thing is happening to me except when i turn on my computer, you can see the screen and its flickering then a few seconds later it turns all black.. :( !!
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
