Televison & Video Logo
Mark Mourning Posted on Feb 16, 2019
E55do vizio with new power board still blinking screen
Dre Young
Level 1:
New Friend:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Feb 23, 2019
Dre Young
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
17
Questions
0
Helped
10194
Points
39
Replace the buffer boards. they are called the y z boards
2 Related Answers
wachshazza
  • 4 Answers
  • Posted on Dec 21, 2014
SOURCE: My vizio E370VLE is getting no power at all. The vizio logo under the screen isn't even lit up. I have tried plugging into new outlets and even switch out the power cord with a new one so i know its n
the problem is probably your main power board.. these can be replaced by yourself.. find the model no and then enquire about a replacement board ..I have had similar problem tv repairman wanted $500+ to fix board only cost $134..make sure to disconnect power supply ..undo all the screws around back of case including wall mount and base follow power lead entry into case do not touch any circuitry as some capacitors store power disconnect the little plugs that run from the boardundo the 4 screws and replace with purchased replacement board and re assemble..
gopakumarg43
  • 76851 Answers
  • Posted on Jan 22, 2015
SOURCE: I have a Vizio E422VA that will get to the Vizio logo screen, hold for about 1 minute then power off with the power light blinking for about 2 minutes. I have replaced the main board, power supply boa
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Testimonial: "The blink code does not apply for this model. It seems more of a firmware issue. Someone suggested the 30 seconds reset multiple time which seem to do something because now the tv powers on and goes to the Vizio logo screen and just sits there. After about 2 minutes, it power cycles. I currently have an Ethernet cable and a blu ray connected to it to see if it detects any incoming signals. So far nothing."
Vizio V585-H11 blinks white screen
I've seen this issue many times on this series of Vizio sets, you have a bad EEPROM IC on the main board, either change the main or order and solder in a new IC if you have advanced soldering skills, needless to say the chip will be a fraction the cost of the board.
2answers
Vizio TV that won't turn on gets 5v standby power but 19v for all the pins that are supposed to be 12v.
There may be faulty electrolytic capacitors on the power board check for them first by looking at the ends for bulging or leaking
Blinking screen with picture after new power board
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
I have a Vizio XVT3d474sv. My TCON went bad, only one side of the screen was working. I ordered a new TCON for it. I had been checking over other things and was lightly tapping areas to see if somethi
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
2answers
Vizio E422VA 42 in LCD television power light blinks
Hi I have Vizio e422va it's not turn on only front power light is on white when I plug power coward no led no screen is black please help
Vizio screen problem. Please help!
The screen is ok Your T-Con board quit. You can get a new one from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
