Televison & Video Logo
Question about Vizio Televison & Video
Vizio V585-H11 blinks white screen
Woke up one day to our Vizio V585-H11 not working. When powered on, it blinks white and black over and over forever. The audio works fine. Have gone through all of the standard options of troubleshooting to no avail (factory hard reset included). I even replaced the TCon board. I know nothing about TVs but read somewhere that most problems are solved by changing the TCon board. Not in this instance. Any ideas? The lights and everything seem to work and it has power. All connections seem fine. Am I down to a mainboard replacement? It literally blinks all white and all black with zero picture on the screen. Help!!!
Posted by Sean Hoffman on
Larry
  • Vizio Master
  • 4,587 Answers
I've seen this issue many times on this series of Vizio sets, you have a bad EEPROM IC on the main board, either change the main or order and solder in a new IC if you have advanced soldering skills, needless to say the chip will be a fraction the cost of the board.
Posted on Aug 14, 2022
2answers
VIZEO V585-H11 tv screen turned white
Take it in for repair or try and claim on the 3 year or 1 year warranty. They are a budget brand.
3 year warranty
https://www.vizio.com/en/three-year-warranty-policy
1 year warranty.
https://www.vizio.com/en/terms/warranty-and-returns
2answers
Need advice in fixing Vizio TV model V585-H11 Video
It can only be a bad connection or one of the 'new' boards you put in was faulty. Start swapping back the old boards one at a time. Make sure any ribbon cables are properly seated.
This Tip I wrote a while back explains the problems you face.
https://www.fixya.com/support/r29790007-repairing_own_television
1helpful
What might be the problem on my Vizio XVT373SV HDTV that will not turn off and on properly?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
The Visio on front blinks orange and white with black screen
The tv is powering down when flashing. Hold the power button down for thirty seconds, this will shut the power down completely. \do this after you unplug it. than plug it back in. it will still blink but only for a few seconds then you should be able to turn the tv on
2answers
Vizio E422VA 42 in LCD television power light blinks
Hi I have Vizio e422va it's not turn on only front power light is on white when I plug power coward no led no screen is black please help
Vizio m470nv will not come on, logo blinks orange to white.
It may not be the caps at all, a lot of the new LED Back-Lit TV have faulty LEDs. They short and pull down the power supply, and to a novice it will seem like a bad power supply. That means that you must replace the bad LED's in that particular LED strip before you can fix the problem. Not an easy repair for a rookie.
I have a Vizio VW42LFHDTV10A -- The first time I
Please check for bad electrolytic capacitors on both main board & power supply, if there is any "pup-up" one, replace it (them).
Top Vizio Televison & Video Experts
Marvin
Marvin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
