Model # 116.21514012 VC will only operate with the carpet power-head attached, but has no suction. When using handheld feature, it will not turn on at all. Bag changed / no clogs / no hose holes / checked filters / no damage to wiring.
SOURCE: clogged vacuum hose
I used a snake like they sell for unclogging pipes. I can use the snake on one end to break it up. I attach the other end to my industrial wet.dry vac and **** it clean. Sometimes I cannot imagine how it fills half a five gallon bucket of dog hair and stuff.
SOURCE: we have a Kenmore canister vacuum cleaner. the
Your hose could be bad. The wires frequently go bad up by the handle switch. also could possibly be the wand, those go bad. You can check that by attaching your powermate directly to the nozzle without the wand and see if the same problem is there. Do you have the mini powermate also? the one that is usually mounted on the wand. If so plug that in directly to the hose and see if you have the same problem. If that tool works fine then the problem is in the powerhead.
SOURCE: I have a Kenmore canister vacuum cleaner. The
check the reset button or the wire that goes into the powermate sometimes it frays and breaks
SOURCE: Kenmore canister vacuum cleaner won't start
The rigidity of the Power Head/Handle is quite durable, :) but sometimes they give out. Have SEARS ...loL, sears, have Sears have a look at the head. :)
SOURCE: We have a kenmore canister
Hard to say without the correct model number.
However, you could check these things first:
1- Is the belt that runs the brushes on the end pieces broken? If it is, is needs to be replaced.
2- Is there power to the control head that is not operating? This is a guess on my part since it is not possible to know the makeup of your unit without the model number.
Check these things and let me know how you make out and we can go from there, as long as I can get the model number.
Paul
