SOURCE: have a kenmore model 110.64962300
Before you begin, UNPLUG DRYER.
Remove bottom access panel by using a putty knife to depress panel clips (item 46).
Check the High limit fuse and heater for continuity. Heater (item 14) <20 ohms and HI-limit (item 47) <0.3 ohms.
If the heater or HI-Limit has failed it may be that the exhaust airflow has become blocked or restricted. Check the hose in the back ofthe machine for crushed hose. If OK, the vent pipe may need cleaning...check out www.linteater.com for vent cleaning info.
If you need further assistance please let me know..
Regards
reg501
The FixYa Team
SOURCE: Kenmore Electric Dryer 110.62922100/Runs but no heat
remove the lower front panel. the element is right there with all the access screws and wires. check the thermo relay also known to go bad..................
SOURCE: Whirlpool GEW9868K Electric Dryer remove back panel
You will need to pry the front corners of the top to open and then remove the front to get inside. Please unplug first , Thanks, Sea Breeze
SOURCE: How do I access the drive for my LG Tromm LG
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
SOURCE: GGQ9800PW1 How can I remove the back panel?
Newer models have access through the front lower panel. Removing the panel will expose the t-stats and all other parts. Remember to disconnect all power to dryer before servicing. Disconnect the wires to the thermal fuse and join them together. Connect dryer and start, if it heats up then your fuse is bad. Costs about 10 bucks.
