SOURCE: when I try to use my vacuum the hepa filter blows off the front of the vacuum
sounds like the latch is broken. get a new filter door at a vac shop
SOURCE: back filter and its door blows off as soon as I turn it on.
thats good has good suction i guess there should be a cover on that back filter if you can't find you can tape it down leave air coming out
SOURCE: water leaking from out of the heppa filter
Reasons for that to happen:
a) You have tilted the vac while vacuuming
b) Used the Rainbow without separator (basket like thing on the bottom of the motor)
c) Overfilled the rainbow tank with water (may have happened when shampooing with AquaMate)
Clean and install back the separator, remove HEPA, Set the Rainbow on empty water pan (with HEPA removed) turn it on for a while so everything will dry. Install new HEPA.
You will have to get a new HEPA filter (you can find them HERE)
Good Luck,
Rocky
It seemed like an awful large amount.
The filter is likely clogged and needs replaced.
