I turned my tires to the right to pull out of a parking spot, and heard a very loud bang, cannot see anything but i hear metal clanging when I hit a bump in the road
Hi from the uk this bang you heard is most likely to be the coil suspension spring on the nearside most likely the top coil has broken this is not uncommon fault however slightly expensive but not beyond d i y if you want to save money it would be worth checking both sides and if you shop around you can obtain springs at reasonable price have done one recently on focus cost £56 here in uk time to diy if you have haynes manual it will give detailed instructions on renewal you will need to borrow spring compressors hope this helps keep in touch if you req further info/assistance good luck
You may have to remove the tires but they are very well known for braking the front coil springs.
