SOURCE: digital scale question
Digital scales purport to measure your body fat through a process called BIA, or bioelectrical impedance analysis. Essentially, it clocks the speed that electricity travels through you. The scale runs a low-level electric current through your body, using your feet as positive and negative electrodes. The current encounters different levels of impedance, or resistance, from fat versus muscle. The scale measures this impedance, and throws it together with other factors (age, sex, height) to come up with your BMI, or body mass index.
SOURCE: Watchers WW-87 Body Fat Glass Scale
Hi
At this web site bottom left hand corner there is an instruction manual
http://www.conair.com/weight-watchers-glass-digital-scale-p-667-2_60_38.html
SOURCE: Need to reset a set of avon curves body weight
You cannot clear out the memory but you can overwrite each Person. I could not find instructions online anywhere, so I looked at Weight Watchers scales and found a sililar one, downloaded the .pdf instructions and followed them on my Curves four button scale.
Click here for those instuctions
http://www.conair.com/instruction_booklets/07AD15010%20WW31%20IB.pdf
SOURCE: Conair #WW78 scale doesn't reweigh
;i have a problem with the conair ww78. It does not reweigh. It shows the same weight each and every day. What is the problem and how can it be fixed?
SOURCE: I need to set up my health-o-meter BFM920 digital
Hold down the button for the person you want to setup (1 or 2) until the displays shows the height and the number of feet start blinking. Use the up and down arrows to change the numbers and the Set button to move to inches, age and gender.
