It ran fine yesterday, tried to start it today and it turns over but won't start. I disconnected the battery hoping something would re-set, but that didn't work either. Any ideas?
Can you hear the fuel pump hum for a couple of seconds when you turn the ignition on?
What if I put in a new fuel pump it just stop on me me no lights nothing can u help
If it won't crank or no electricity, check that battery terminals are contacting properly and that battery isn't dead. If it does still crank but just died while you were driving along, check that fuel pump is getting power. also check fuses.
i cant here the fuel pump cycle could it be bad
It may be your ignition module, but good luck finding one, but really it could be anything. check spark, then fuel and narrow it down to one or the other.
Always check for spark and fuel. If it doesnt have any of those it will not start up. You need to pull a spark plug wire carefully and use a phillis screwdriver and put it in the end of the plug wire and put it close to metal and have someone crank it over and check the spark. If no spark you need to check or replace crank sensor. Check for fuel pressure. Check for injector noid firing. Injectors use the cam position sensor.
My Dad has one of these and he figured out that the ignition has a grease in it that is not very conductive, to solve the problem he sprays electrical cleaner in the keyhole and take cover off and spray the back electrical side of the ignition. note: you have to work the key back and forth while spraying. (ONLY USE ELECTRICAL CLEANER) NO WD-40 or any other oil, you will fry the ignition. we get it at Wal-Mart and is called {CRC QD Electronic Cleaner} in a red and white can.
petrol... or gasoline here in U.S.
petrol
Is it diesel or petrol?
