29 inch ultra slim tv horizontal section R503 value
SOURCE: I have an Onida 29
All lasma an lcd ts have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times reseating the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em. but if otherwise
Panel is faulty. probably bad connections inside the panel.
Good luck.
SOURCE: onida 29 inch trueslim tv how to unlock volume
Sound issues and answersa short list:
sound on set or a box muted or turned down?
speakers inside the set (see menu) switchedon or off?
internal/external switch somewhere in or on back of set?
Clearly it could be a audio problem (a model number?) but explore all here thatyou have not already done--make sure theremote set to TV and look for a button on it marked MTS and if there cycle it.
You can also determine if same trouble when you play a DVD
SOURCE: i need the fly back number for a s 29 inch Ultra Slim Color television
Most newer sets do not have such a part (PLASMA OR LCD)---if a regular tv set call the maker with the model number for this information---Google that model number to see if it even has one----sets with this part are going away very soon.
SOURCE: i have onida 29 tru slim tv how can i unlock the volume because its lock?
how to unlock the all programes in onida true slim 29 inch tv
