You could try puchasing a replacement bobbin case, its possible that the tension spring on it has worn/stretched a bit. Try this website if you are in the USA -
http://www.sewingpartsonline.com/bernina-707-sewing-machine-parts.aspx or just go to the bernina website and choose your country to find the head office in your country. They should be able to sell you the part or direct you to a local dealer closer to you.
Also clean out the top tension device if you haven't already. Turn to zero and floss between the discs. I use a clean selvage edge of a waste piece of cotton fabric or you could use dental floss or ribbon too, just something to get in there and remove any buildup. Thread, especailly darker colours, will shed dye particles and fibres and over time this can build up in the tension discs impairing their function.
Otherwise, sounds like you've had a really great run with your Bernina - if you don't already do this, then consider taking it for a service every two years too as the internals benefit from a lube on the older mechanical machines. It may be that the top tension device needs replacing to resolve your issue.
