SOURCE: My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
SOURCE: Jazzy wheel chair
When a chair sits for a long period of time ( four weeks or more) without being charged, the batteries die. To help you with the freewheel mode I would have to know what model of Jazzy it is.
SOURCE: Power good, but no motor functionality - Jazzy Select
hand control is locked. turn chair on push joy stick forward til it beeps then pull it back until it beeps then put it in neutral ( joy stick in the center) then it should be unlocked
SOURCE: Our Jazzy Select G.T. power
Hi LOCKING/UNLOCKING THE VSI The VSI has a feature that enables you to lock your power chair to prevent unauthorized use. To lock the VSI: 1. With the VSI powered on, press and hold the on/off key. After one (1) second, the VSI should beep. 2. Release the on/off key. 3. Push the joystick to the full forward position until the VSI beeps. 4. Pull the joystick to the full rearward position until the VSI beeps. 5. Release the joystick. There should be a long beep. 6. The VSI is now locked. To unlock the VSI: 1. Press the on/off key and power on the VSI. The maximum speed/profile
delobner,
Sometime we lock our vsi joystick by mistake. Here are the instructions on how to lock and unlock your joystick.
If the problem is still there after write me back and I'll help you.
indicator should ripple side to side.
Good Luck
mi mobility
SOURCE: Jazzy 1121 power chair won't go
I find a lot of the controller Problems are caused by the cable running from the joy stick down to the controller gets caught on something or rubbed against something and one or more tiny wires inside are broken ... If I find a spot on the cable that is worn through, that's where I start .. Open up the insulation and check the tiny wires .. fine the broken one and repair it .. usually that solves the problem and saves you a couple hundred for the cable
