SOURCE: dryer won't start
Check the thermal fuse with an ohm meter, if there's no reading its bad. The thermal fuse is located just above the vent outlet, its white has 1 screw attaching it to the housing and is about 1-1/2" x 3/8". Once you remove the screw it slides to one side and will pull out. It has two wires connected to it. You will have to remove the back cover of the dryer to access it. First unplug the power cord from the receptacle.
SOURCE: light comes on wont spin
Check the door switch. It just might be sticking which is why the light remains on and the dryer won't spin...
J. Lewis
SOURCE: "Control Locked" light is lit and dryer won't run.
turn the lock off by holding the button down for 10 seconds
SOURCE: the dryer won't run and
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
