SOURCE: i need to reassemble a crossman airgun model 760-D
i need a website adress or link to a understandable diagram of how it goes together
SOURCE: How to put back together a smith & wesson air soft rifle
ooof i know how to put i back together and can teach you but its a doozi over the net. hows your experiance with airsoft internals also wat type of gun is it (spring gas aeg etc shotgun assault rifle pistol etc. email me @ [email protected] i can help you further with that info
SOURCE: I have a crossman 4x15 power rifle scope. Which
Under the adjuster cap there should be a scale with an arrow marked up or right (depending on which one you are looking at. If it's not marked, place the gun in a vise (gently as not to crush it, cover metal parts with a towel)
Fire the gun while in the vise at a large sheet of paper several yards away (careful where the bullet goes...use bails of newspaper or plywood backing)
Sight through the scope and move the cross-hairs 'till they are exactly on the bullet hole. After you have done that, keep increasing the distance and adjusting up to compensate for bullet drop till you reach your desired range. Side to side adjustments should only be minor. Before sighting in, make sure that the scope is securely mounted or any adjustments you make will be irrelevant. While sighting, always use a bench rest...shooting "off-hand" will never give you any degree of accuracy because everyone moves and shakes a bit.
SOURCE: Hello, i have a Crosman 760 Pumpmaster Air Rifle,
Sounds like it has a bad o-ring. you can take it apart and replace the o ring for under a dollar. just make sure you look at how it goes back together when you take it apart they are very simple. just make sure the carefully take the right side cover off with the left side of the rifle laying on a table, everything should stay assembled this way so you can look at it. the part you are looking for is in the large chamber that the pump goes into. from the back (the side opposite the pump) remove the spring and the metal piece behind it, then use something the shove the big brass part out of the chamber and the o ring is on the big brass part . take the old o ring to a hardware store to get another one.
Testimonial: "Thanks! i didnt know anything about this before and now everything so much clearer. Thanks Again! Joe."
