Video showing how to set a similar watch:
https://www.leaf.tv/articles/how-to-set-the-date-for-a-timex-expedition-indiglo-watch/
How to Set the Date for Timex Expedition Indiglo Watch LEAFtv
SOURCE: How to set time on Diesel DZ 7071 Watch
Just figured it out!! Press and hold Set/El button. Wait until LIGHT On/Off (or similar) flashes on screen. When it does then press the Mode button to scroll through various functions including setting the time. Hope this makes sense and helps
SOURCE: Timex Expedition, beeps very quietly and indiglo doesn't work.
To clarify... Replace the cover with the arrow on the back pointing directly at the stem. The Indiglo backlight, alarms and chimes should all work when the back cover is in this position.
SOURCE: timex expedition indiglo wr 50m
I had the same problem, and could not find any answers on timex.com. After you place the battery in and it begins to beep, push all four buttons in at the same time. This should "reset" the watch -- at least it did for me.
SOURCE: Timex Indiglo Acqua watch
For analog Acqua watches adjust date when month has less than 31 days:
3-Position Crown: Pull crown to "MIDDLE" position and turn CLOCKWISE or
COUNTERCLOCKWISE until correct date appears.
2-Position Crown: Pull crown to "OUT" position and turn CLOCKWISE until date
changes (approx.1:00 a.m.). Then turn COUNTERCLOCKWISE to 7:30 p.m. Repeat until correct date appears.
SOURCE: Acqua Indiglo water resistant watch with alarm 30m
Press and hold the MODE button (bottom left) for approximately 3 seconds.
When the Alarm set time starts flashing, press the MODE button once
more. Now the seconds for the watch time should be flashing.
Use the START/STOP button (top right) to move bewteen items and the SPL/RESET button (bottom right) to change the item.
Moving between all items, it will take you through: seconds, minutes,
hours, month, date, day of the week. Simply press MODE when your
settings are complete.
