BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;}
a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;}
a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;}
a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;}
a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;}
Once you have downloaded the manufacturer's software and your webcam is
working on your computer,you can now configure it to Yahoo Messenger.
Its
good practice to disconnect and re-connect your webcam before you start - if you
have been using it elsewhere the Yahoo software may have difficulty in locating
it. Mine, I just unplug it from the USB and plug it back in, if yours is
integral with the computer you will have to re-start the computer, unless the
software has a feature for this.
Of all the chat programs, Yahoo is the most
painful software to set up but if you follow these instructions you should be
ok.
INTERNET CONNECTION
Webcam connected
Open messenger - on top
toolbar. Left click ( > ) Messenger > Preferences > Connection - Select
'no proxies' or 'connect direct to the internet' depending on the version of
messenger you have
make sure your internet connection and country are correct
in the lower two boxes > Apply > OK
TESTING
> Messenger > My webcam - the warning panel will launch,
click 'OK' and your webcam will start. You should be rewarded at this stage with
your happy smiling face.
DEFAULT
With webcam still running > Messenger > Preferences >
Webcam > Camera Source - set your webcam as default using dropbox. >
Camera Settings - adjust settings to suit. > Apply > OK
Take a note of
any additional software, if you have multiple choice for Camera Source, you may
wish to uninstall any redundant webcam software later to prevent conflicts
PERMISSION OPTIONS
> Messenger > Preferences > Webcam - make
your selections ( who you will allow to view you) > Apply > OK
IN USE
When you are both on line and wish to show your webcam >
Actions > 'Invite to view my webcam'. This will launch an invitation on your
contacts screen when they 'Accept' your webcam broadcast will start- There can
be considerable time lag ( 1 minute) before they see you, so dont be too
impatient ( You can check the status on the bottom left of your webcam panel.
You can 'drag and drop' the frame to a convenient location by grabbing the top
border.
There is a shortcut ( cam picture ) in the toolbar and one down by
your pic as well but these do not always work
Your contacts needs to
configure their connection the same as above or they may get a "webcam not
connected" message
If you complete the above and still have problems - check to see if your
cam is compatible with Yahoo
YAHOO SPECIFICATION
To find out what the requirements are for messenger
webcams, check out the following.
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/webcam/mstacamreq.html
