Https://www.jackssmallengines.com/diy/how-to-change-the-oil-on-a-husqvarna-walk-behind-mower/
use the dip stick to measure the oil level there will be a F on the dip stick to show where full is. Wipe the dip stick with a rag and then put back in to measure the oil. Not mentioned about the rag in link above !
You can do this with cars too !
SOURCE: oil level YZ 125
Hello....for the crank case you will want to use Yamalube 4 (10w-30) or an equivalent SAE 10W-30 SE motor oil. There is not a dip stick on the bike, Need to measure teh oil in accordance with Yamaha specs. You will need to check the owners manual or contact the local dealer service department and should be able to tell you how much needs to be added. If you don't have good 1qt mix cup you can get one at a good motorcycle shop. These are very help full in accurately measuring your premix oil for the fuel as well. Hope this helps
SOURCE: Mercedes 190 E 2.6 blown head gasket?
sound like intake gasket leak.it will leak oil into the cooling system.
SOURCE: Mower engine cuts out at exactly 1/2 full tank of gas
When that happens loosen the fuel cap and see if it stays running. If this is a gravity feed system make sure you have the correct fuel filter on it,the clear paper filters can allow vapor lock to happen,put the small briggs and stratton filter in it,which has a small chamber and a stainless screen.Also make sure there is no excess fuel line that would cause a dip or a high spot for a vapor lock to occur.
You have governor with a missing spring or it could be in the wrong place. If the springs are all OK then you may have a bad governor gear in the crankcase. This engine is bad about the governor gears bending the governor gear shaft.
SOURCE: I have a Craftsman Briggs and Straton 650 Series
some of those have a safftey swich that the bag has to push dowen so it will fire
