SOURCE: Change ******** Anne Klein watch
Your watch comes with interchangeable bezels, not faces. Bezel is a ring or rectangle (depends what shape your watch has) surrounding a glass.
All bezels are mostly friction fitted,so, to remove your bezel you need to use a strong knife blade and press it between the bezel and the case. The bezel should lift up.
To get the bezel back you have to press it into place.
For changing the strap you have to turn watch upside down and using the knife or lug tool try to squeeze sprigbar end out of the watch lug. Sprinbar is the piece which holds a strap attached to watch. The end of springbar you will find exactly where the strap is attached to watch. Push it inwards and it must come out. The rest is like 2x2.
Good luck.
SOURCE: anne klein watch battery replacement
My Anne Klein uses an EverReady #377. The internal time module from Hong Kong is stamped with "AL21E."
I hope this helps you.
SOURCE: I can't get the back off of my Anne Klein watch
Take your watch to your nearest watch shop and ask them to do it for
you.
You can get into difficulty replacing batteries and it is
not worth the risk for the small cost saving in doing it yourself.
SOURCE: need a watch band clasp extender
Click on my profile (escapement), then click on Tips and Tricks. There you will find how to order parts from AK. Rate me, please.
SOURCE: Replacement clasp for Anne Klein watch, caseback #12/6130-1
mcdevito75 here, Your in a spot with your Ann Klien watch. BEST BET, shop ebay and match up another Ann Klien just like yours and use for parts. On ebay Click in search, watches then Ann Klien.
