SOURCE: Omron model 650 not inflating and measuring
Lucky! Wrist BP monitors never provide accurate consistent measurements.
SOURCE: WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
SOURCE: Omron hem-704C blood pressure monitor show down
If your HEM 704C fell hard, it is probably the pressure transducer that is faulty, broken. To my experience it is cheaper to buy a new one then to have it repaired by a technician
Testimonial: "Sound advice."
SOURCE: Sunbeam7650 Don't know how to properly set the Pressure Selector
The switch tells the machine how high to pressurize the cuff when it starts. It needs to somewhat higher than your normal systolic pressure (mm Hg). (So if your systolic (top number) bp is regularly between 100 and 130, set the switch to 160.) Similarly if your systolic pressure is regularly above 130 but below 170, set it to 200)
I hope this helps.
http://www.foodsaver.com/manuals/HAH/Manuals/7657.pdf. Good Luck, Jet...
Hope this helps you out
