How to mirrorimmage samson tablet totv set - Samson Audio Players & Recorders
How to set up Samson G-Track Pro?
Hi, have you tried the G-Track Pro on another computer, to see if it repeats the fault?
I sent you the link so you can download the user manual of your Samson
I hope you can solve the problem
Greetings Franco Dosil
Hola, has probado el G-Track Pro en otra computadora, para ver si repite la falla?
Te env?o el link para que puedas descargar el manual de usuario de tu Samson
Espero puedas solucionar el problema
Saludos Franco Dosil
http://www.fixya.com/answer/answerpageslideview.aspx?ctg=mine&fml=0&brd=0&p=2&thid=27347935#
I have a samson c01u and using audacity. i set the input level in the control panel to 100 and also in audacity, but the the volume is still too low. i can barely hear my voice. what do i do?
1. Did you select Left channel only in Audacity for the track you're recording?
2. Maybe it's a defective mic. Try it on another computer/software/USB cable/USB port and if it still doesn't work get Samson to replace it.
My Samson Carbon 49 keyboard controller. Under Device Manager/Sound, video and game controllers - DTMB BDA TV USB Properties General, This device cannot start. (Code 10).
1. Go to devices and printers.
2. Double click SAMSON Carbon49 to open
3. Hardware > properties > General > Change settings > Driver > Uninstall.
4. Turn off the device and turn it back on.
5. Hardware > properties > General > Change settings > Driver > Roll back driver.
Should work now
Hi There, My samson airline wireless 77 mic has stopped working. Can somebody please advise of the best number to reach a samson tech support or service centre on? Thankyou!
Shipping Address:
Samson Technologies Corp.
45 Gilpin Avenue, Suite 100
Hauppauge, NY 11788
Phone Numbers:
Phone: 631-784-2200
Fax: 631-784-2201
Primary E-mail Contacts:
Information - [email protected]
Sales - [email protected]
Support - [email protected]
Literature Requests - [email protected]
Direct Brand E-mail Support:
Samson Wireless - [email protected]
Samson Audio - [email protected]
Hartke - [email protected]
Zoom - [email protected]
International Contacts:
For Samson Audio, Samson Wireless and Hartke please use our International Distributors Page to find the contact information of the Distributor for your country.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
How do I install my dish network satellite to my new 47" panasonic?
We would be happy to help you with that. We would recommendvisiting our "Set up receiver to TV"page here:http://www.dishnetwork.com/SupportSection/setup-receiver-totv. We hope thisinformation helps you. Thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
3helpful
Can you change the operating frequency of a Samson
No, the Stage 5 series are fixed-frequency units. They come in a variety of channels (the new 200Mhz range model has 28 different ones) but they're factory-set, and not programmable, so the frequency you pick when you buy one is the frequency you're stuck with.
MY JOB DEPENDS ON THIS!!! SONY DSR PD170 AUDIO PROBLEMS
Appreciate the direct "Ask Me".
The Sony PD170 is not an everyday equipment, nonetheless, I will assume that on the Sony DSR PD170:
  • the Samson UHF M32 receiver is plugged to Audio 1;
  • boom mic is plugged to Audio 2; (or vice versa) and
  • Both Audio 1 & 2 are using the XLR connectors.
Assuming that your boom mic is a conventional dynamic, on the Audio Control Panel, pls set:
  • INPUT 1 -
  • MIC CH SELECT CH1&CH2
  • INPUT LEVEL MIC
  • +48 OFF
  • INPUT 2 -
  • INPUT LEVEL MIC
  • +48 OFF
This is of course assuming that both the boom mic and the output of the Samson UHF M32 receiver are set to MIC level. In some instances the Samson UHF M32 receiver requires a LINE setting. The only time the +48 is set to ON is when the mic that is used/plug in requires phantom power such as condenser types. If the mic or the Samson UHF M32 receiver requires power then this should be switched ON otherwise, there will be no audio coming in. Though most M32 uses a 9 volts battery.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
SETTING LEVELS ON MY POWER MIXER FOR MICING DRUM SET
Go check out these pictures, and there is some good info about micing up your drums. :) Recording it is then a case of getting levels good for a start by worling your way around the kit one drum at a time setting the level for that drum. a bit of nice reverb in the mix and out come you drums.... whoooohhooooo
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
