20 Most Recent
Samson AH1 Professional Headset Questions & Answers
MY HEAD SET WILL NOT TURN ON. WHEN I POWER ON THE
There are several problems with those headsets.
If you're using them for aerobics, then look inside the transmitter.
Often those little switches have corosion due the sweath.
Another problem are is the microphone element and wiring to the transmitter.
Good luck,
Gerard
Samson Airline 77Watrproof Hdset keeps dying on me.
THE PROBLEM YOU ARE DESCRIBING HERE IS A FADING VOLTAGE ISSUE, TRANSCIEVERS DON'T FADE OUT LIKE THIS, THEY JUST QUIT AND END OF STORY, YOU MAY HAVE A BATTERY CAPACITY ISSUE, THIS MAY BE DUE TO A DEFECTIVE BATTERY
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
