Remove rear fender @
SOURCE: illustraited instructions to remove a starter from a Harley soft
no pictures 1 remove the battery neg cable, 2 remove the primary chaincase on left side or bike it is held on with 3/16 allen bolts be ready to catch the oil thats comes out (3/4 of a quart replaces it) 3 remove the small 3/8in bolt that is in the center of the starter shaft (small gear at top of case) 4 go to other side and look at starter see the two large allen bolts at sides remove them now with a little pulling it will squeez out from under the oil tank if not loosen rear oil tank bracket that will help this should help you
SOURCE: how to shut off alarm on a 2002 harley davidson heritage soft tai
I long push on the remote turns it on, 2 quick clicks turn it off.
SOURCE: how do you remove the front fender on a Harley
Depending on the bike.. On all the "easiest" thing to do is drop the front wheel, remove the 4 bolts holding the fender on. Watch out for the sheet metal tabs that lock the bolts in place. Now depending on the model you may have a light on the front of your fender, you will have the joy of disconnecting it first. Hope this helps.
JP
SOURCE: harley davidson presure tires
At my shop we run 40 psi front and rear and find we get max wear on the tires.
SOURCE: remove rear fender on
The bolts needs to be removed.They are very tight, but actually comes out.---------- Click this link below and follow the step by step instructions:--- http://howtobyme.blogspot.com/2011/06/how-to-remove-rear-fender-on-2006.html ------------------ This will help,.Thanks.Helpmech.
