This means that only your fan and emergency electric heater is working. The good thing is that we know the fan works. The bad thing is that the condensing unit isn't kicking on. Put your unit into regular heat and go outside to your condensing unit and see if it is running. If it's not, check your breaker and fuses at the outside unit to make sure the breaker is on and the fuses are good. Post back with what you find out and we can go from there.
SOURCE: Amana Heat Pump Emergency Heat will not come on
On the heating element [behind the coil, (the springy thing)], at the top end of the element, there is a little thermistor I think it is called. You will have to remove the fan shroud. With the power off, check for continuity if you have a multimeter. If that is the problem (no continuity), you can pick one up at al local heating supply. Just have it soldered back in and reconnect. If the thermistor 's continuity is okay, remove the main board under the control knobs. I have seen these boards burn in the back where the relays are soldered on. If you're really good with a solder you can try to re-solder it. If not, it's about as cheap to buy a new unit as it is to buy the board. Good luck.
