I've returned 5 of these already, they all stay on once you use them the first time. LED never turns off. Costco couldn't figure out how to turn them off either but asked me to stop buying them since they 'obviously don't agree with you'. i just want a device that actually can be turned off when you're not using it so that its battery isn't dead when you need it. Its really a horribly made product.
SOURCE: fat max laser is in inches need feet
Press and hold the "+ - units" button and hold for over one second. It should then let you select your units of measure. In this case it should be the second selection, which is "0.00 ft". If you lost your owners manual, you can download one at www.engineersupply.com/Manual-and-Help-Docs/Stanley-TLM100-Manuals.pdf. If you find this helpful, please rank the solution.
SOURCE: looking for instruction manual for Stanley Fat Max
The manual is available at the Stanley support site: http://server.iad.liveperson.net/hc/s-44183334/cmd/kbresource/kb-5162309471456573043/view_document!PAGETYPE?sq=FatMax%2b77-189&sc=2&sf=101113&sg=1&st=405165&documentid=342296&action=view . The direct link is: http://server.iad.liveperson.net/hc/s-44183334/cmd/kbresource/kb-5162309471456573043/!DOWNLOAD?entryid=342296&attachid=29375 (but I'm not sure this will work).
If you have problems with those links, start at: http://server.iad.liveperson.net/hc/s-44183334/cmd/kbresource/kb-6221370935515628266/front_page!PAGETYPE?category=2 . Enter 77-189 in the search box and then click on the link.
I hope this helps.
SOURCE: Have a Stanley Fat MAx
there is a little black button on the end where the blade comes out. With the blade in the out position,push in the button and pull out the blade. With button pushed insert new blade or turn the old one around to use the other end.let go of the button and you are ready to go.
SOURCE: How do you put blades
I had to go onto You Tube to figure this one out.... turns out its really easy. I still cannot believe Stanley couldn't bother to include instructions!
http://www.youtube.com/watch?v=B8Q1p-8jkyE
Enjoy!
