SOURCE: Cannot perform set-up for Accu-Chek Performa
Hi, yes sorry but you will need to purchase new strips.
SOURCE: address of the
accu chek active is not working properly.where is the service center at tirunelveli
SOURCE: Hi there, my accu-chek machine
The Owners Manual is available for download in a pdf format at the Accu-check website.
Simply do a Google search for their home page.
SOURCE: Accu-Chek Active - E-1
Hi There!
An E-1 error, accompanied by an image of a test strip, indicates that the test strip is damaged or the code key is incorrect.
Try reading on this site: https://www.reference.com/health/accu-chek-aviva-error-codes-mean-b8ef274185187192
I hope this helps you out!
SOURCE: What is a E-1 code for an ACCU-CHEK meter?
"E-1" in the display means the test strip may be damaged or the code key is incorrect. Remove and reinsert the test strip.
have inserted a test strip that has already
been used or is too old. Clean the
measurement optics (Chapter 7.1) and
repeat the test with a new Accu-Chek
Active Glucose test strip."
17.January.2015
17.January.2015111
