SOURCE: Mitel Superset 4150 will not conect
This phone is a digital phone and requires connection to a digital system commonly called a "key system". If you have removed it from where it was connected and tried to use it at home or somewhere else it will not work. Most home or normal phone jacks are connected to your local provider directly and is what is called an analog system. The 2 are NOT compatable without an interface device. If it is connected to a key system then thier is a problem with the port on the Mitel keysystem that goes to the jack you are plugging the phone into and you will need a technician to fix/rewire this onsite. Hope this helps you. A manual for your phone can be gotton here: http://www.octelephone.com/4150user.pdf
SOURCE: How do I set the date and time on mitel superset
The time and date come from the Mitel Telephone system, not from the telephone set itself.
You need to access the Mitel system to make a time change.
If you can get into the system, goto the Group Administration and click on time...the rest is self explainitory.
SOURCE: How do I put my Mitel Superset 4015 on speaker
Sorry to tell you, but the Superset 4015 is not capable of doing this conference feature.
It has loud speaker capabililties (for paging, or listening to calls), but no microphone for your conference meeting.
SOURCE: my superset 4015 mitel corded displays locked
repeat the connection and the unlocked no if you have it better use it
SOURCE: Need to clear messages from phone
Here's a link to a user's manual for your phone.
http://www.comm-links.co.uk/download/Mitel%20Superset%204015%20User%20Guide.pdf
Page 26 discusses message handling.
I hope this helps you. Good luck!
