SOURCE: Change the amount of times it rings before goes to V-mail
In Coverage path form for voice mail
COVERAGE CRITERIA
Don't Answer? y y Number of Rings: 2
COVERAGE POINTS
Point1: h2 Rng: 1
you can change Number of rings,Rng options
SOURCE: Extending Ring Time
You can try the steps below:
A) The simplest method is to call your carrier and request a longer ring time, up to 30 seconds.
B) If you have a GSM based phone, some have had success by dialing this number from your phone: **61*XXXXXXXXXXX**30#
For example, the T-Mobile voice mail access number is 18056377243, and thus the string to dial would be **61*18056377243**30#
SOURCE: NEC Dterm 80 calls won't go to voice mail
for us i just found this out.
1.Fwd B/NA
2.1 - 1:set-0:cancel
4.200
5.speaker
after 4 rings it goes to voicemail
this works for us.
i hope it works for others too.
turn this feature off
1.hit fwd b/na
2.0:cancel
3.exit
4.exit
should see the normal display then.
SOURCE: phone won't ring
Check your call options to see if something called "Call Forward" is on. That might be your problem.
SOURCE: Extending number of rings before voice mail engages
Is the caller being transfered to the ext or is it on incoming calls?
Tony
