Most likely is the defrost terminator thermostat in the cooling coil inside the fridge, it is round clipped to the coil.
Most fridges have a cooling vent above or on the side of the top shelf. This is where most of the cold air comes from, so keeping food away from here may preventfreezing. ... Some side-by-side refrigerators (particularly older models) feature a vent that funnels cold air from the freezer into the fridge.4 Aug 2015
How to Prevent Your Refrigerator From Accidentally Freezing Food ...
refrigerators.reviewed.com/features/how-to-prevent-accidental-food-freezing-in-fridge...or try this link...
refrigerator keeps freezing things Google Search
SOURCE: Delfield Refrigerator/Freezer Condensation forming outside door seals
I would expect at the very least a heater circuit around the freezer door. Some of the commercial units also have sprung doors to keep the doors firmly shut which you could check by opening the doors. Door heater circuits are normally very reliable and it would be worth checking the voltage is getting to them, they are also a pain to change out. Hope this helps.
SOURCE: Refrigerator door gasket
This area is hot as it is a mullion heater to stop condensation from occurring during humid days. New units use the high pressure line from the sealed system to do this. Your unit may have poor circulation causing the compressor to work harder as a result. Clean your condensor coils and make sure you have a bit of space so the air can circulate around the unit.
Sgt 48
SOURCE: Whirlpool Side by Side Refridgerator
the heater in the gasket area is on when the unit is cooling (compressor running). hot weather makes unit run more, hence the heater is on longer and gets warmer. Coils under the unit being dirty or many door openings can also cause extra run time.
J
SOURCE: Coil is freezing on freezer
Yes, the seal will let outside air into the unit causing the coil to ice up. When it ices up the air cannot blow through the fins in the coil, thus no cold air goes to the refrigerator section.
SOURCE: Gasket seal around refrigerator and freezer doors is hot.
This is likely part of the defrosting feature and if it is always hot, the defrost timer has failed and is keeping the seals hot.
The defrost timer is normally located behind the lower grillwork and many are equipped with a slotted shaft that can be turned with a flat-bladed screwdriver. The slot will also let you see if the clock motor inside is running.
You would need to mark it and give it time since these things rotate only once every 12-24 hours.
