I also purchased a KabelfDirect Optical cable 10' Item ID 275, PID 2000006, 10'. It was a duplicate item . I would like to return both items. How do I do this?
SOURCE: Optical Port 2
i have the same problem - the only thing i have found so far is that I have to go into the setup on the amp and change the input for dvd from optical 1 to optical 2 and back again to switch between 2 devices
SOURCE: Optical Mouse double clicks on single click
Go to control Panel and click the mouse option. You can change it there
SOURCE: Stylus Pen Broken: LeapFrog Explorer Smart Globe (Item Id: 40002)
Hello Sushil,
If in the US, Call their Consumer Services number at:
1-800-701-5327
They will be able to help you get a new one.
Thanks for using Fixya and consider rating this solution.
Wayne
SOURCE: WHERE CAN I DOWNLOAD THE SOFTWARE OF MY MICROSOFT WIRELESS OPTICA
just download ur driver from ur mouse manufacturer website
SOURCE: How do I return an
As long as the item is
within 30 days based on the date of purchase, then you should have no
problem returning this to Amazon. All you have to do is to go to their
Return Center and fill out the information.
http://www.amazon.com/gp/css/returns/homepage.html/ref=hp_901888_gen_orc
Before
you do this, you might need to check too if you bought it directly from
Amazon or thru Amazon Marketplace. Amazon Marketplace means that you
bought it thru a reseller that displays their products in Amazon. In
this case, you might need to contact the reseller directly.Phone numbers
are usually located in the invoice you received. Never open the
duplicate nor put any markings on its box. This will let resellers
charge you a restocking fee which costs around 10-20%.
