SOURCE: golf cart smoking
It is most likely related to the rings, but running it would unstick them very fast if they were stuck. It's possible that sitting let rust develop in the cylinder walls and there may be some grooves in them now. They could also just be really worn cylinders. They make some oil conditioners which I wouldn't recommend on a car, but might work fine on a golf cart. I can't recall the name, but it was in a silver can, maybe called engine restore... You could always try that before resorting to a rebuild.
Testimonial: "thanks for your advice. I will try an additive before a rebuild."
SOURCE: Electric Golf cart only shutters and inches forward
so many possibilities...
does it roll fairly freely? (checking to see if the brakes or rearend seized up)
Are there any "bad" sounds like things grinding? (Connection between Motor and rearend, axle splines...)
If all that is solid, it is likely in the controller.... (it takes a solid charge right... No bad batteries in there or loose connection? might want to check all the battery connections to make sure none are burnt...)
1997.. does it have the electonic speed control by that year? the other possibilty is that the accelerator is not working corectly. they used a resistor system on old ones that has contactors that would get worn out.... Newer ones control a potentiometer(sp) that controlled the speed.
Only a few real components to check, but if you are not mechanically and electically inclined, could be tough to isolate.
peace,
SOURCE: Yamaha 4 stroke golf cart back fires all the
Very important... valves get out of adjustment and are easy to set. This is where I would start FOR SURE. Check out www.buggiesgonewild.com and an example of how to do it on EZ GO 295 http://www.buggiesgonewild.com/ezgo-gas-tech/1196-ezgo-295-350-engine-valve-adjustment.html
SOURCE: 1993 Yamaha golf cart Ser#
Hello
The serial number of the Golf cart does no good to ID it. I need the model number and the displacement of the engine as well as the number of cylinders and what year it was produced..
SOURCE: I got 1997 yamaha G16
Hi and welcome to FixYa, I am Kelly.
The new carb. fuel mixture adjustment screw should be very close to the setting needed to operate the engine normally. You should not have to move the screw more than 1/8 th turn in either direction from the current ORIGINAL setting.
You mentioned the engine smokes really bad. Several things cause a smoking engine:
1. Older engine
a. Piston oil rings stuck to the piston skirt or rings worn out
b. Piston wear
c. Cylinder wear
d. Valve stem and valve guide wear
e. Valve head and valve seat wear.
f. Crankcase breather clogged
g. Overserviced engine oil.
Perform a compression test on the engine. You should have a minimum of 120 PSI pressure. The higher the pressure the better. If the cylinder compression is under 110 PSI the engine needs some serious maintenance.
I can not emphasize enough that the new carb needing any major adjustments is a symptom of other problems within the engine. Like I mentioned earlier if you have to make a fuel mixture adjust more than 1/8 th turn in any direction from the original setting something else is wrong.
IF by chance someone got over anxious and has moved the fuel mixture screw start at 1.5 turns from just barely closed. I am surprized that the new carb did not come with a plastic cap over the mixture screw.
Thanks for choosing FixYa,
Kelly
