Innovage 1604007 Corded Phone Logo
Anonymous Posted on Jul 28, 2009
Can I change from pulse to tone and how. Don't see a switch anywhere on phone
kxtd500
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Jul 29, 2009
kxtd500
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
Helped
8379
Points
30
What type of phones are these? Looks like RCA on pictures if so there is a setting in those but I think it is set in the programming on the menu you will need the instruction manual to program that phone many buttons to push to get to it.
wiccan8thhouse
Level 2:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 49 Answers
  • Posted on Jun 15, 2010
wiccan8thhouse
Expert
Level 2:
Night Owl:
Answers
49
Questions
0
Helped
21058
Points
112
If you still need help with your phone try this.....
The manual you need, you can download it from the link below -- It was made and uploaded by me, so it is safe....
http://www.megaupload.com/?d=8EIJ8RH3
Hope this helps --WICC--
Please , i want to change to pulse
Usually, phones have switch-button for Tone/Pulse mode situated somewhere on its body. I don't know what phone you wrote about. - I can't find it on Internet.
2helpful
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Phone changed from tone to pulse. there's no switch on the base to change from tone and pulse so how can i change this. vtech 2461
There's a switch on the bottom of the base unit to switch between tone and pulse. It's marked "18" in the illustration on page 6 of the manual at
http://vt.vtp-media.com/ecp/documents/product_Product/1249/UserManual/2839/vt2461_manual.pdf
How do you change the dial tone from pulse to tone?
is this a land phone? if so look on the side of the phone you should have a switch (T/P) switch towards T...cell phones you go to settings/network/switch fax/tone/pulse/data...
How can i change my tone from pulse to tone
check to see if there is a switch on the base of the phone. It should be a small switch that will say PULSE/TONE.
2answers
Change from pulse dial to tone dial.
You will find a small switch on side of phone that says Pulse - Tone, choose Tone..
13helpful
10answers
Changing from pulse to tone dial
For the GE electric 2.4 GHZ phone where there is no switch, you have to press the program button and hold until it beeps (talk button will start flashing), then press the tone (star) button and program again. It will beep for confirmation
2helpful
8answers
Cordless telephone sw/from pulse to tone
dear,
check this link and hope it will solve the problem
http://www.epinions.com/content_56960192132
regards,
2answers
TC1200 TONES/PULSES
There is usually a switch to change it from dial pulse to touch tone.If there is no switch check your user manual to see if there is a screen option.
tk46
10helpful
Polycom Sound Station
SoundStation: Changing dialing from Tone to Pulse
http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=10966&sliceId=SAL_PUBLIC_1_2&dialogID=979138&stateId=0%200%20977279
Description
sp.gif sp.gif There are three ways that a SoundStation can be changed from tone to pulse, which depends on when the unit was manufactured.
1. Pressing the Keys 3&Vol + simultaneously, will toggle between Pulse and Tone while the unit is in On Hook Mode (off).
2. Pressing the Keys *&MUTE simultaneously, will toggle between Pulse and Tone while the unit is in On Hook Mode (off).
3. Operation done by DIP switches. Dipswitch Configuration On the bottom of the SoundStation, in the lower left hand corner of the large sticker may be a small silver sticker. Underneath that sticker are 4 DIP Switches. Switch number 4 is for tone and pulse,ON being tone, and OFF being pulse. Do not change the other three swithces as this could render the phone inoperable.
Top Innovage Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
