SOURCE: Spline drill bit won't spin
There a a few things to look for, first is the selector on top in the hammer only position or hammer with rotation. Second look at the spline bit, does the splines look worn excessively also try and look in the nose of the tool for spline condition and last the clutch mechanism might have come apart. Good news though this tool might be covered under warranty, some had a 5 year coverage.
SOURCE: broken shaft 3/8 milwaukee hammer drill mod #5392-1
Yes it does. The collar mechanism and retaining ring come off and under all that is a sleeve with steel ball bearings, what I am saying is it would be better to take to a repair shop. I worked on this tool for years and they are decent to use, but repairing that without proper equiptment is not fun. Let me know your area and I will try and find a repair center for you.
SOURCE: stopped working in mid drill. squeeze the trigger, nothing happens
It could be a dirty switch connection in the trigger assembly , it happens to me on my electric sanders all the time , just open it up and try blowing it out with an air compressor
SOURCE: I have a makita hr2455x rotary hammer drill that won't hammer
you need to get that service,
the grease causes the hammering.
and probably too much pressure was applied
to it.
SOURCE: which is the best rotary hammer drill to buy
Hi
yes it is a good tool all deppend on what kind of work you want to
do with it ,
just remamber this is not a jack hammer it is a light impact
Hammer Drill. and it is a problem free if it used for the right
work and load.
