Heating & Cooling Logo
J
John Jee Posted on Sep 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My bryant model # 582A stop walking. The led indicator show 1 flash---Fan on/off deley modified
When I set to cooling Large fan run but no air come out inside the house
Thomas Woodburn
Level 3:
  • Master 2,638 Answers
  • Posted on Sep 25, 2017
Thomas Woodburn
Master
Level 3:
Answers
2638
Questions
Helped
1252018
Points
7008
It lost a leg HAHAHA
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
5 Related Answers
Anonymous
  • 540 Answers
  • Posted on Aug 23, 2008
SOURCE: KELVINATOR KSR20C
One might think so, YES! look on one of the door panels that you can remove! Thank-you-very-much!
docjohn174
john gagnon
  • 943 Answers
  • Posted on Sep 27, 2008
SOURCE: not cooling
hi thanks for the question is the compressor running hot if its not hot and the fan by the compressor is running the problem is that the compressor is not starting check the compressor you might need a new start relay mounted on the compressor thanks the appliance doc
Anonymous
  • Posted on May 03, 2009
SOURCE: Why Wont My Bryant Furnace Stay Running
You have a dirty flame sensor, it needs to be replaced
Anonymous
  • 116 Answers
  • Posted on Aug 28, 2012
SOURCE: My American Standard Heritage 11 unit was not working properly when i came home from work and the temperture in the house according to the thermostat show the temperture in the house to be 85 degree&#
the dual run capacitor is bad located in main panel of unit size of small red bull can it will be swelled up on top indicating it bad get on at electric motor or electric supply house most ac stores wont sell it has a rating like 35/5 370
Brian Mills
  • 613 Answers
  • Posted on Aug 30, 2013
SOURCE: Ruud Heat Pump
Check to see if there's low voltage reaching the contactor's coil. If there is. and it doesn't close (pull in), then it's defective and should be replaced. Cut the power and check ohms to be certain.
Error code 72 on Bryant Evolution air conditioner model 186BNA036-A
Code 72 usually has to do with start components. Either run or start capacitor could be bad, or start relay could be bad.
https://www.youtube.com/watch?v=FQisFmMtAis
2answers
2002 4 ton Bryant air conditioner shuts off, fan still runs but not cooling is problem in the controls in the attic or in the AC unit or both?
With a non heat pump it is a simple 24 volt AC control circuit. In the attic there is a relay that is actuated via the fan control wire directly from the thermostat. On the thermostat there is an auto/man switch that controls the fan. Manual the fan runs all the time. Auto fan turns on and off with the outside compressor.
If the system is not calling for cool and the fan continues to run the fan relay is sticking. common problem. Sometimes after running for several days the relay will stop sticking if not, replace relay.
If the system is calling for cool and the compressor stops I would still expect the fan to run until thermostat tells the A/C to off. Some compressor units include a safety switch or high-pressure cut-out switch A blocked internal valve bad control board or external fan in outside unit defective no air flow in outside unit.
High pressure cut out not good,
Suggest turning temp max cool and observe. If acceptable cool and the compressor runs without interruption all is good, except for the blower in the attic. Safely check relay in attic blower circuit.
Hope this helps.
I have a Bryant 661CJ030-E. While in cooling mode
Refrigerants are regulated by the EPA. In order to purchase it, you need an EPA License. If you are low on refrigerant, the leak needs to be found and repaired. This requires special tools.
Additionally, with the information given, it could be an electrical problem. Is the outside fan running, is the compressor running? Your best bet is to call a professional.
I've a Bryant AC/Heat system. Model 661CJ030-A. It run cool okay but the fan kept to running even get to the point that has been set.The system seemed not auto stop. Any ideas,
Hi if the indoor fan continues to run after the unit is done cooling, you either have a fan relay located in the indoor unit that is bad or stuck, or a problem in the thermostat with the fan contacts not opening when its satisfied. Pull the cover from the thermostat to expose the wiring. Find the G/Green wire. This is the fan wire. Take a small screw driver and carefully loosen screw and take this wire off. Give it a couple of minutes to see if it shuts off. If it does shut off, the thermostat is faulty and you will need a new one. If it still runs, you will have to check the indoor unit and find the fan relay. If this system is gas fired for heat, it will have a combination fan/High limit control that is the problem, more then likely stuck. Look at the wiring diagram on the panel and it will show you the fan control. You can try tapping on it to see if you can un- stick it. If not, it will need to be replaced. If its just a fan relay, it will be black about the size of a wooded match box with around 5 wire terminals on it. If you have someone turn the stat on and you should be able to hear it click. Do the checks with the stat and let me no the out come and we can go from there.
Shastalaker7
Tv desn't turn on,power light just flashes ten times and then stops and then again
Error Indication Information
Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
(Note 3) (Note 4)
POWER LED TEMP LED
Note:
1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
change to another every 5 seconds in turn.
3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
or accumulated operation time of the Air Filter reaches 400 hours.
4.LAMP OFF: The LED will flash right after the Lamp goes off.
5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
6.IC6001 is mounted on TV Main C.B.A.
Clogged air filter
more than 90%
15)
16)
17)
18)
1)
2)
3)
4)
5)
6)
7)
11)
8)
9)
10)
12)
13)
14)
- flashes 5 times -
every 5 seconds
IC2301(pin82) detects the clogged air filter, then indicates the
error when the air filter is clogged 90%.
Front Fan stop or
Lamp Fan stop
flashes orange
once every
5 seconds
IC2301(pin12) detects the Front FAN stop or Lamp
FAN stop, then indicates the error when the Front FAN
or Lamp FAN is stopped.
Lamp Cover open
Temperature Sensor
short or open
flashes orange
twice every
5 seconds
flashes orange
3 times every
5 seconds
flashes green for
140 seconds.
flashing red for
60 seconds.
light up red.
flashes once
every 5 seconds
flashes once
every 5 seconds
flashes red for
10 minutes
flashes once
every 5 seconds
Abnormal
Temperature
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Request for Lamp
Replacement - - lights up
Power Ballast Error
(abnormal
Lamp voltage)
flashes 3 times
every 5 seconds
Power Ballast Error
(abnormal
temperature)
flashes 4 times
every 5 seconds
Power Ballast Error
(other causes) - -
Request for Filter
Cleaning -
Abnormal Voltage
on 16 V line of
LCD Main C.B.A.
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Abnormal Voltage
on 14 V line of
LCD Main C.B.A.
flashes 3 times
every 5 seconds
flashes 3 times
every 5 seconds
Abnormal Voltage
on 7 V line of
LCD Main C.B.A.
flashes 4 times
every 5 seconds
flashes 4 times
every 5 seconds
IC2301(pin76) detects the Lamp Cover Unit condition
(open or close), then indicates the error when the
Lamp Cover Unit is open.
IC6001(pin85) detects the Duct FAN stop, then
indicates the error when the Duct FAN is stopped.
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
IC2301(pin74 and 75) detects the temperature attached near
the Front FAN by the Temperature Sensor (R2911) on Front
Thermistor C.B.A., then indicates the error when the
temperature becomes more than 43 C (109 F).
IC6001(pin86 and 87) detects open or short of the
Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
then indicates the error when Temperature Sensor is open or
shorted.
(The error is not detected for 4 minutes after Lamp ON.)
the Lamp by the Temperature Sensor (R2901) on Lamp
temperature becomes more than 60 C (140 F).
IC2301(pin11) detects the error of LCD Power C.B.A.,
then indicates the error when the temperature fuse
(117 C)(243 F) in LCD Power C.B.A. is open.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp
is cracked.
IC2301(pin11) detects the error of the Lamp, then indicates the
error when the Lamp is short-circuit.
IC2301(pin48) detects +16V line voltage on LCD Main
C.B.A., then indicates the error when the voltage
becomes less than +13V.
IC2301(pin47) detects +14V line voltage on LCD Main
becomes less than +11V.
IC2301(pin45) detects +7V line voltage on LCD Main
becomes less than +5.7V.
IC2301(pin44) detects +3.3V line voltage on LCD Main
becomes less than +2.5V.
flashes 3 times
every 5 seconds
flashes 4 times
every 5 seconds
Abnormal Voltage
on 3.3 V line of
LCD Main C.B.A.
- flashes 5 times
every 5 seconds
Forced cooling
The failure of Lamp
light up
Temperature Sensor
short or open
Abnormal
Temperature
Duct Fan stop -
When accumulated operation time of the the Lamp reaches
5000 hours, OSD (replacing the Lamp) appears on the screen.
Note: The Lamp time is stored in EEPROM (IC2305).
When accumulated operation time of the Air Filter reaches 400
hours, OSD (cleaning the Air Filter) appears on the screen.
Note: The Filter time is stored in EEPROM (IC2305).
During forced cooling, this indication is indicated.
IC2301 (pin11) detects the failure of light up processing of
the Lamp, then the POWER LED is changed as follows.
1) POWER LED flashes green for 140 seconds (while turning on).
2) POWER LED flashes red for 60 seconds (while cooling).
3) POWER LED lights up red (standby).
Note: If the Lamp will not light after attempting turning on the
power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
LCD Main C.B.A. may be defective.
Error Symptom Problem Possible Solutio
Bryant central air unit fan doesn't stop.
This is a condenser fan and as long as the A/c unit is in cool mode, this fan will run. The only time it should shut off is when temperature setting is satified and the unit shuts off.
2answers
Look on the blower door panel in the wiring diagram there should be a flash code but it sounds like the flame sensor is not picking up the flame and you may be able to clean it
Top Bryant Heating & Cooling Experts
john h
vince
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
