Ebay is a good place to look: e.g. http://www.ebay.com/itm/like/181199648582?chn=ps&dispItem=1
Go to Ryobi's website to get that part
SOURCE: Featherlite trimmer primer bulb
Hi
Check the hoses from primer bulb to the carb.
best regards savumihai71
SOURCE: ryobi 825r 4 stroke grass trimmer fires momentarily then stops.
I would say try adjusting the carb screws further out,or start by winding all the way in then out 1,5 turns.
SOURCE: Ryobi 790r trimmer has low power and stalls
Maybe a quick fix and maybe not
check your muffler the factory puts a spark arrestor screen that tends to plug after awhile
there is a little plate on the side muffler that needs to be removed to access the screen you may need a torx bit or allen wrench to remove
you may have to remove the back half of the plastic cover to access the screws
remove screen and clean with carb. cleaner or equivalent make sure you can see through it and reverse the procedure to put it back
SOURCE: replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from
the carburetor to the bottom of the tank. Leave enough slack in this
line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The
other
fuel line goes from the primer bulb to just inside the tank,
(about an inch). make sure that you get the right size fuel lines. The
plastic coupling goes on the end of this line, inside the tank. This
keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an
angle. They will feed much easier into the holes. You can than cut them
off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
SOURCE: Broken Primer Bulb
Get the model number and go to:http://www.psep.biz/store/homelite_trimmer_parts.htm
