SOURCE: Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
SOURCE: LG DRYER MAKING CLUNKING NOISE
Look inside the drum at the seam, front and back side. The weld on the stainless steel drum may have cracked. You would need to replace part number 3045EL1002F. It is moderatly difficult to replace.
SOURCE: DRYER IS MAKING A CONSISTENT BANGING NOISE WHEN RUNNING. DRUM IS TURNING AND DRYER DOES DRY OK.
There are several things that can cause a dryer to be noisy. There
are a lot of moving parts in a dryer that can cause noises to occur
when they get worn. Several parts support the drum, and may make noise
or vibrations when worn out. Many times a dryer will squeak just a
little bit as it first starts. This should go away in just a few
seconds. Make sure nothing is loose inside the drum. Remove the lint
trap and look below the lint trap holder for any loose items that may
have slipped through the cracks.
The blower wheel is
always moving and lint is constantly going by it. If it’s noisy, it may
have gotten clogged with lint, or it may be worn and need to be
replaced. Clean out the area around the blower. If it’s still noisy,
replace it.
Many dryers use a center spindle to support the clothes drum. This
spindle may be a ball-and-socket support, or it may be a shaft inside a
sleeve. When these component bearings get worn out, they may make a
squealing or rubbing sound. Replace this bearing when it gets worn out.
Many dryers also use plastic glides in the front end of the clothes
drum. When these glides are worn out, you may hear a lot of noise. If
the glides are worn, replace them as a set.
Some dryers use rollers to support the clothes drum. If these
rollers or wheels are worn out, they can be extremely noisy. You ought
to replace the whole set at the same time. A belt that has been damaged
or frayed may make a thumping or slapping sound as the drum turns.
The gas valve solenoid will make a buzz type of sound as it opens.
The valve itself will give a little click as it starts the heat cycle,
when ignition begins, and when the burner is turning off. The burner
flame itself makes kind of a low-pitched roaring wind sound.
Thanks for using Fixya.
SOURCE: LG DLE2516W Dryer suddenly making loud vibrating noise
Until you know how serious a problem you have, I'd advise against continued use. If you are in the USA, go to http://www.lge.com/us/support/repair/support-repair-provider-lookup.jsp
to find a service provider for in warranty service, or call LG USA at 800-243-0000.
SOURCE: LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
