12 volt issue
SOURCE: ac problem
Static pressure(Non operating) usually is around 70 lbs and should be even on both sides. Sounds like the systen is too low for the computer to allow operation. I suspect a small leak somewhere. Adding as little as 1/2 lb should allow operation and leak testing.
SOURCE: Which fuse controls the 12-volt outlets. I have
check the accessory fuse, might be labeled as a cigarette lighter or accessory.
SOURCE: 2005 Crown Vic climat contr fan not working Fuses good Motor good
does it have a digital control panel? As this uses an electronic blower speed controller located at the engine compartment (rear engine block) fix on ac phlenum try to shake the connector or wire while the system is on.
SOURCE: No power to left side
Then you found it also the window lock switch can also affect it use this diagram to help you you have a control switch on the driver side problem
